Track use-tires
If you haven't tracked before, start w/ the OEM recommended cold pressures and then check them at the end of each session. The faster you get the hotter the tires will be, obviously, and eventually you will have to start letting some air out. For the stock PZeroes I'd recommend hot pressures of 34/38ish front/rear. The rears get greasy over 40 in my experience.
Feelgood MD
Mar 24, 2016 09:35 AM
WearyMicrobe
Dec 10, 2015 04:06 PM
albert@velosdesignwerks
964
Sep 9, 2015 11:48 AM
WheelB
991 Turbo Vendor Classifieds
Sep 3, 2015 10:26 AM
