Level1tec 991 Turbo and Turbo S Tuning
Old Oct 9, 2014 | 12:00 PM
MAXRPM1's Avatar
MAXRPM1 has a spectacular aura aboutMAXRPM1 has a spectacular aura aboutMAXRPM1 has a spectacular aura about
Originally Posted by kodiakz
So, with that said, can you log somehow and retune as needed for max gains?
Aaron McEvoy with MAXRPM here
Yes we can do logging and re-tune if needed. Also here are some dyno videos
Old Oct 9, 2014 | 04:08 PM
willcoxmd's Avatar
willcoxmd is infamous around these partswillcoxmd is infamous around these parts
Originally Posted by MAXRPM1
MAXRPM Motorsports is proud to announce that Level1tec.com now has performance tuning software available for the 991 Turbo and Turbo S - also being released are Level1tec performance kits - pretesting has been very encouraging and final tuning will take place this week on a new 991 Turbo S - will give final performance results first of next week...stay tuned!!
Hey guys, I'm the proud owner of the TurboS that Alex and his crew just finished tuning. I have known Alex for 10 years and he has worked on several of my toys. I like to say that MaxRPM has always maintained the highest standard of workmanship and customer service. I was a bit nervous about tweaking my new car, but I spoke with my dealer (who knows Alex well and have excellent rapport). I was assured that my warranty was not in jeopardy and I trust Alex. With that being said, they have transformed my refined beast into a tarmac devouring monster! The car was already stupidly fast, now it's just ridiculous. The acceleration is so rapid, so linear and so smooth. Alex took my car on a Friday and delivered it to me Tuesday, I haven't shaken my adolescent grin all week. Thank you MaxRPM, you never disappoint
Old Oct 10, 2014 | 10:05 AM
MAXRPM1's Avatar
Todd - Thanks for the kind words... I think you need a oil change soon? We're kind of busy but if you drop it off on Monday I might be able to get back to you by the weekend... don't worry, I won't disconnect the speedo!! LOL
Old Oct 11, 2014 | 09:02 AM
kodiakz's Avatar
kodiakz is a splendid one to beholdkodiakz is a splendid one to beholdkodiakz is a splendid one to beholdkodiakz is a splendid one to beholdkodiakz is a splendid one to beholdkodiakz is a splendid one to beholdkodiakz is a splendid one to beholdkodiakz is a splendid one to behold
Porsche 991 Turbo and Turbo S Tuning 1 on Vimeo
Sounding better and better! Can do logging and retune without removing unit from car? map switching? would we work with you using etunes?
Old Oct 17, 2014 | 11:39 AM
MAXRPM1's Avatar
Yes we can do log file without removing the unit. Map switching currently can only be done with the buttons on the outside of the box. (we are working on the switch on the fly option currently) e-tunes are currently not available on these but this is something we are looking into as an option.
The biggest thing is that wireless can only be done with data-logging as of now since the rate at which is required to transfer information, (downloading uploading, and live tuning) from the laptop to computer needs a direct connection without any loss of signal :-)
-Aaron with MAXRPM Motorsports
Old Oct 17, 2014 | 08:49 PM
kodiakz's Avatar
stage II maps coming? thinking plenum, turbo back and filter with tune pretty much get max power out of the beast without building anything
Old Oct 19, 2014 | 10:34 AM
Snorman's Avatar
Snorman is infamous around these partsSnorman is infamous around these parts
Originally Posted by enzom
Edit - or am I confusing E85 with the gas that is supplied in the winter (which I think is more oxygenated).
It is the latter.
The higher ethanol blends are not E85.
S.
Old Oct 20, 2014 | 06:40 AM
aboodchy's Avatar
aboodchy is infamous around these partsaboodchy is infamous around these parts
This looks impressive indeed. Just a quick question if you don't mind, how do you guys dyno the car? I was told the Turbo S can not be dynoed safely because of a new axle system implemented on the new models. I have several modifications on my car and I'm dying to dyno it
Old Oct 20, 2014 | 04:51 PM
MAXRPM1's Avatar
The kit we just tuned basically had a stage 2 (Fab-speed system, IPD Plenum and high flow filter).That basically is all you can do unless you do a custom CAI system. Also as for the Dyno procedure we have never heard that you cannot Dyno the Turbo S. It may be if you try doing it on 2WD Dyno's. Ours is an AWD Dyno and we always run all the newer vehicles in AWD mode because of the traction control and other variables that need to see all 4 wheels spinning at the same time.
-Aaron with MAXRPM
Old Oct 20, 2014 | 08:00 PM
kodiakz's Avatar
so were the results you posted with all those mods? if not, what are the max gains with those? do any of the 997 turbo cai setups work with the 991 by chance? wouldn't mind building necessary hardware as long as there are no MAF codes or errors
Old Oct 20, 2014 | 11:02 PM
aboodchy's Avatar
-Aaron with MAXRPM
Thank you for your insight. Will keep that in mind and all will try to dyno it now.
3WDistributing
31
Oct 27, 2017 01:26 PM
Regent
Aug 21, 2015 11:14 AM
Aug 21, 2015 09:56 AM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 18, 2015 03:43 PM
