Dealer tune...anyone??
Old Dec 5, 2014 | 09:44 AM
White Rock's Avatar
White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !
Originally Posted by White Rock
Getting my car back today from Porsche of Plano with the same setup. I now several guys with this setup and it is one of the best you can get. You won't have warranty issues with P or Plano. ..
PM me if you want a referral or more information
Old Dec 5, 2014 | 10:04 AM
buzzm's Avatar
buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !
Getting my car back today from Porsche of Plano with the same setup. I now several guys with this setup and it is one of the best you can get. You won't have warranty issues with P or Plano either.
who's tune/flash is it ?
Old Dec 5, 2014 | 10:06 AM
White Rock's Avatar
I went with the VR tune from Vivid. However, that dealer normally uses the Eurocharged tune. I got a great deal on mine, so I decided to try out VR. My buddy has the Eurocharged setup and I can't tell the difference in the two.
Old Dec 9, 2014 | 11:50 AM
Panguard's Avatar
Panguard is infamous around these parts
Originally Posted by wrs
ParkPlace offered a better deal than that to me.
Here is what Park Place told me a couple of months back.
Here is the list of some upgrades we can perform on your 2014 991 Porsche Turbo S:
FVD headers: P:$1849.00 L: $639.76
GIAC flash P: $3500 L: $455.25
IPD intake Plenum P: $950 L: $455.25
BMC engine air filter P: $208 L: $78 if bumper is off for another service. L: $225 if performed by itself
Champion Motorsports Diverter Valves P: $350.00 L: $298 – requires removing the rear bumper
I think the service set up at Park Place looks pretty good. However, since I live in Austin and I didn't want to drop the car up there for a week, I went with the FVD piggyback, FVD headers and the plenum.
What the hell.. charging $455.25 for labor on a software flash? Something that they can do while they're installing the hardware? Sheesh! I mean I would understand $100-200 (shouldn't take more than 1-2 hours since it is OBD-II) .. but $455.25? Holy moly.
Old Dec 9, 2014 | 12:27 PM
wrs's Avatar
wrs
wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !
I believe that is legit since they have to remove the DME and send it to GIAC unless things have changed now. At the time they gave me the quote, I think it was a three day process to get the GIAC flash. I don't know if that has changed for the initial flash. I think an update may be possible via OBDII but not the initial one. OCICBW
That is one reason I liked the piggyback better and the fact that I had already gotten a quote from BlackJack speed shop in SA for $2200 for the GIAC flash not including labor which I think they said was three hours. Same deal with them though, car had to be there three days.
Old Dec 9, 2014 | 12:36 PM
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
The GIAC flash for the 991 Turbo is done via OBDII. The entire process takes about 30 minutes to complete.
However, the dealer selling the flash has to be an authorized GIAC retailer, and thus have the necessary OBDII cable and GIAC flashing software on hand in order to be able to do it.
Old Dec 9, 2014 | 12:51 PM
wrs's Avatar
wrs
So has this been the case all along? I was told it was a three day process back in September. That the DME had to be removed and sent to GIAC.
Old Dec 9, 2014 | 12:53 PM
It's been OBDII since long before September...pretty much since the flash was released.
The reason you were told the DME had to be removed is most likely because the dealer you went to was not an authorized GIAC installer, so they don't have the necessary equipment to flash it. In those cases, the DME can be removed and sent to GIAC for flashing.
Old Dec 9, 2014 | 01:26 PM
wrs's Avatar
wrs
I found them on the GIAC website. It's moot anyway as I went with the piggyback to match the rest of my FVD stuff and I am very satisfied with the result.
Old Dec 9, 2014 | 01:28 PM
hmmm...I don't have an answer for you then. It is, and has always been, an OBDII flash. It could just be that they were misinformed.
Old Dec 9, 2014 | 03:55 PM
PMNewton's Avatar
PMNewton Is a GOD !PMNewton Is a GOD !PMNewton Is a GOD !PMNewton Is a GOD !PMNewton Is a GOD !PMNewton Is a GOD !PMNewton Is a GOD !PMNewton Is a GOD !PMNewton Is a GOD !PMNewton Is a GOD !PMNewton Is a GOD !
I contacted Austin@GIAC and he said that they (Park Place) are an authorized installer. If they do still have to send out the ECU then I'm not sure why. There is another authorized installer in Dallas. Look up www.autoscope.net. They have three locations in the DFW area. I'm sure they can do it for much cheaper but if Park Place is dangling the warranty over your head if they don't install it then I'm not sure if that is advised. The flash is the flash and there's nothing fundamentally different about Park Place plugging in a cable and autoscope plugging in a cable. The ones and zeros are the same either way. You could probably fight the dealer on it or ask for a better price.
- Patrick
Old Dec 10, 2014 | 12:05 PM
Andrew@GIAC's Avatar
Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !
N/A 991 models were sent here for programming. The 991TT models have been 100% OBD2 flashed since day one. Now, all 991 models are 100% OBD2 flashed.
Old Dec 10, 2014 | 12:10 PM
wrs's Avatar
wrs
So probably they gave me a quote for the 991 since it's cheaper than what Park Place gave me?
PV=nRT.
Sep 9, 2022 06:06 PM
Axxlrod
Oct 26, 2015 11:54 AM
JVOJVO
Sep 20, 2015 07:55 PM
