IPD Y Pipe and Carbon Install
Old Sep 25, 2015 | 10:45 PM
  #31
White991TT's Avatar
White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !
Originally Posted by webcarconnection
How about the trap speed in the 1/8 compare w/o the Y Pipe?
Couldn't hook. My buddy who was watching the race commented that I had wheel spin at all 4 tires and the car was wiggly on launch.
Surprisingly traps were the same before and after @ 100 mph as I picked up in the 330'.
Old Sep 26, 2015 | 07:20 AM
  #32
webcarconnection's Avatar
webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !
Ok thanks for the info
Old Sep 28, 2015 | 10:12 AM
  #33
cm09578's Avatar
cm09578 has a reputation beyond reputecm09578 has a reputation beyond reputecm09578 has a reputation beyond reputecm09578 has a reputation beyond reputecm09578 has a reputation beyond reputecm09578 has a reputation beyond reputecm09578 has a reputation beyond reputecm09578 has a reputation beyond reputecm09578 has a reputation beyond reputecm09578 has a reputation beyond reputecm09578 has a reputation beyond repute
Are you running the IPD plenum as well, or just the y pipe?
Old Sep 28, 2015 | 10:22 AM
  #34
White991TT's Avatar
Yes installed IPD plenum as well
Old Sep 28, 2015 | 11:17 AM
  #35
cm09578's Avatar
Are there proven independent numbers for both separately or just combine?
Old Sep 28, 2015 | 11:22 AM
  #36
SamboTT@ByDesign's Avatar
Yes it's a great product line and they have great customer and vendor support to back it. The plenums and Y-Pipes have been making over 30 wheel under the curve as well as over-all flow improvement and even faster boost response. Nice work Mike and Greg!
Old Sep 28, 2015 | 12:31 PM
  #37
shifter_'s Avatar
shifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond repute
Had a chance to hit the 1/8 mile track tonight to test the new addition of the IPD Y pipe. Fact is the IPD Y Pipe uncorked big power throughout the range.
The prior week I consistently launched smoothly and consistently without wheel spin at the same track. The only change being the addition of the Y pipe.
Increased power was real and evident from launch. I could not get the car to hook at all. Massive wheel spin while utilizing LC all the way through the 60' and throughout the 330'.
Tried to launch on foot brake on the fully prepped track with the same result.
Guess I'm now in the market for some real tires instead of my stock tires .....
trap speed has almost nothing to do with launch.
sure, wheel spin will slow down your ET, but not trap speed.
stickier tires will lower your ET, but not increase your trap speed.
if the trap speed was the same, it didn't really give you anything.
also, I ran a 6.89 1/8 mi with 103 trap on stock P-Zeros with no wheel spin.
so the tires can do that. I get the feeling your wheelspin issue was the track not a sudden increase in power.
Old Sep 28, 2015 | 02:24 PM
  #38
White991TT's Avatar
Stickier tires can help in the pursuit of doing both, lower ET and a few more MPHs while crossing the stripe.
Think about this .... Wheelspin at launch, couldn't hook well, realized spin throughout the run yet still posted the same MPH.
IMO from having gone to the track, along with the experience in knowing my car and making the runs I picked up HP.
From the vantage point of your computer the track wasn't fully prepared and my tires were adequate notwithstanding the fact that I used a shorter distance to make the same trap speed as before the improvement.
I can't argue that...
Old Oct 25, 2015 | 11:53 AM
  #39
PMNewton's Avatar
PMNewton Is a GOD !PMNewton Is a GOD !PMNewton Is a GOD !PMNewton Is a GOD !PMNewton Is a GOD !PMNewton Is a GOD !PMNewton Is a GOD !PMNewton Is a GOD !PMNewton Is a GOD !PMNewton Is a GOD !PMNewton Is a GOD !
Wow. I didn't realize how wimpy the stock y-pipe was until I saw your side by side photos. I'd better get in touch with Sam. This is all your fault, Nigel...
- Patrick
Old Oct 25, 2015 | 12:04 PM
  #40
White991TT's Avatar
- Patrick
Trust me I feel your pain! However to have Sam consult, look over your combination and make recommendations so that you can breakout from the pack does offset that cost in wasted time and effort. Ask me how I know! Good stuff PMN!
Old Oct 25, 2015 | 12:27 PM
  #41
PMNewton's Avatar
My combination just became full stage III.
- Patrick
Old Oct 25, 2015 | 12:29 PM
  #42
White991TT's Avatar
Awesome! Welcome aboard!
PenguiN
Oct 26, 2018 07:23 AM
PenguiN
Sep 15, 2015 11:44 AM
PenguiN
Aug 21, 2015 10:11 AM
