991 Vendor Classifieds Vendors post your classifieds here
:: ECS Tuning :: Schwaben Tools Are Back In Stock
Old Oct 31, 2012 | 09:39 AM
ECS Tuning - Porsche's Avatar
Most of our tools just recently just came back in to stock. Whether you need to do your brake calipers, or tighten up a timing belt, Schwaben has you covered. These high-quality and long lasting tools will do the job right the first time, giving you more time to enjoy your vehicle where it belongs...... on the road.
Order yours today or give them as a gift. For more information on Schwaben tools and to order
Click Here
Old Dec 7, 2012 | 09:27 AM
All Schwaben Tools are Now On Sale !!
Click Here to view our selection and pick up that tool you have always wanted at that discounted price before our sale ends.
Old Jan 3, 2013 | 01:53 PM
Get those tools you always wanted NOW before the SALE passes you by
Click Here to view our full selection of Schwaben Tools.
Old Feb 5, 2013 | 12:15 PM
Straighten and properly space bent fins with the Schwaben fin straightening tool. Our six-sided tool fits several common fin spacings: 8, 9 10, 12, 14 and 15 fins per inch, so you can work on dozens of car makes.
Click Here for more information
Old Feb 26, 2013 | 02:32 PM
Schwaben spring compressor tools are built with ease of use and safety in mind.
Beefy clamping jaws are wide enough to grip spring coils securely. Spring-loaded locking pins in each clamping hook lock them against the coils so they cannot slip off or turn sideways.
Old Mar 28, 2013 | 02:23 PM
11-Piece Trim Tool kit is designed for removal of door panels, fascia and trim strips, dashboards, and interior panels and window moldings. Made of impact resistant plastic that will not mar surfaces as metal screwdrivers and pry bars will. Slim design for delicate work in tight areas.
Old Apr 5, 2013 | 02:07 PM
Don’t let stripped threads turn a routine repair into an expensive nightmare. The Schwaben metric thread repair kit contains everything you need to permanently repair five common metric thread sizes, in any metallic part.
Old Apr 17, 2013 | 10:55 AM
The Schwaben Low Boy has features and benefits not found in hydraulic jacks sold by mass market suppliers. Its handsome, thoughtful design features a resting jack pad height of only 3.5 inches, letting it snake beneath most lowered vehicle chassis without the need for drive up ramps. A quickpivot single front roller lets it turn on a dime for easy navigation in tight quarters.
Old Apr 29, 2013 | 02:59 PM
The Schwaben Electrical Terminal tool kit is essential for anyone working on European vehicle electrical systems. It contains terminal and pin removal and installation tools in assorted sizes, each with an attractive blue handle for good grip and added leverage.
Unlike small screwdrivers, picks, and paper clips, these tools are the correct size and shape to remove and install tiny electrical pins and terminals at plastic block connectors with ease, and will not damage the connectors in the process.
Old May 7, 2013 | 03:10 PM
The Schwaben 100-piece specialty bit kit includes bits to fit a wide assortment of automotive fasteners, including tamper-proof Torx® and hex bits. Breeze through repairs knowing you can remove odd specialty fasteners with ease.
These bits are made of hardened Chrome Vanadium steel for years of dependable use. Packaged in a handy blow molded case with individually marked bit slots for easy organization.
Set includes:
  • 10 fractional SAE hex, 9 Torx tamper-proof, 9 Torx
  • 9 Metric hex bits, 9 slotted bits, 8 Pozi-drive, 8 Phillips, 4 square-recess, 4 tri-wing
  • 3 spline, 3 Torq, 3 clutch, wing-nut driver, magnetic bit holder and socket bit holder
Due to recent demand we have a few items that are back ordered but most everything is in stock and ready to be shipped out today.
For more information Click Here
Old May 13, 2013 | 02:43 PM
Now you can work around corners with this flex-head Triple Square driver Kit. Beefy vanadium steel bits and durable chrome plated 3/8-inch drive swivel bases are tough enough for professional use. Set of four drivers in M6, M8, M10, and M12 sizes, conveniently packaged in a blow molded carrying case for portability and ease of organization.
Old Jun 13, 2013 | 12:54 PM
This kit is a must-have item for anyone working on European makes.
The Schwaben long reach Triple Square kit contains six drivers with long 5.5 inch shanks to remove engine and suspension fasteners that cannot be reached using standard length drivers.
Large ½-inch drive shanks accept long-handled ratchets and breaker bars for added leverage; chrome vanadium construction makes them strong enough for the toughest tasks. Shanks have ribbed circumference for improved grip when turning fasteners by hand.
Packaged in a handy blow molded carry case for portability and easy organization, the set includes M6, M8, M10, M12, M14, and M16 sizes.
Old Jun 26, 2013 | 10:51 AM
Protect your expensive alloy wheels with extended reach Schwaben Protecta six-point impact sockets. Like our standard length versions, extended length Protecta Sockets have color coded mar-free exterior coatings that prevent nicks and scratches left by plain metal sockets, but reach deeper when standard length sockets just aren’t long enough.
17mm, 19mm and 21mm Sockets Included.
Use these with your breaker bar or impact gun to remove the tightest wheel bolts and lug nuts: when reinstalling wheels, use them to final torque wheel fasteners to factory specifications. Combine these with our torque limiting sockets and the Schwaben ½-inch torque wrench for a complete wheel fastener solution.
Old Aug 5, 2013 | 02:02 PM
The kit contains three 12-point sockets for a sure grip on the most common sized axle nuts, plus three hex drives for removing common hex-head plugs and fasteners. Conveniently packaged in a blow molded case, this set will please the most demanding professional technician or discriminating prosumer.
Kit includes:
  • 30mm, 32mm, and 36mm - 12-point axle nut sockets - ½" drive
  • 14mm, 17mm, and 19mm hex head drive axle shoulder bolt sockets - ½" drive
  • Blow molded storage case
ECS Tuning - VW
Aug 20, 2015 02:01 PM
Aug 19, 2015 06:55 PM
ECS Tuning - VW
Aug 19, 2015 02:36 PM
ECS Tuning - VW
Aug 19, 2015 02:15 PM
ECS Tuning - VW
Aug 19, 2015 11:08 AM
