:: ECS Tuning :: New PigŪ Mat & Dispenser Combo Pack
Car repair is dirty work, and sliding around in an oil spill is no fun. If you're tired of cleaning up spills with old socks and kitty litter, we have a new and better way.
Pig Mat products have long been a favorite in professional repair shops that can't afford to track grease and oil onto costly car mats and carpeting. Made of durable, layered polypropylene, Pig Mats catch and hold most common fluid spills until you can throw them out.
While you're here, check out our video on Form-A-Funnels, a great way to avoid spills in the first place.
Click Here for more information
Oil can get all over crossmembers, hoses, and lines during a filter removal. Eliminate the mess and channel that oil into a drain pan. Bend in any way that you can think of. Wrap it, twist it, and keep it in place as it drains oil away. A mess free solution for oil filters, drain plugs, tight places, or anywhere else you don't have much room.
This 100% polypropylene mat will absorb just about anything that comes it's way. Throw it down on the floor during oil changes and other service to keep everything clean and dry without the mess of cat litter or oil sweep. No dust to track around, keeping your shop cleaner. It’s great for engine rebuilds, transmission teardowns, and a great spot to keep oily tools during work. It’s compact, easy to use, and free of damaging grit and dust and reduces clean up time thanks to its absorbing technology. It can be air dried for reuse and it features easy-tear perforations that let you use a 1/2 pad for smaller spills; more efficient to save money and eliminate waste.
The rugged ABS container has a generous 10 liter capacity, large enough to hold two oil changes from most passenger cars and light trucks, or a single oil change from vehicles with moderately larger crankcase capacities. Large double handles and drain spout with screw cap make it easy to transport and dispose of your drain oil at you local parts store or recycling center. Fill and vent plugs have o-ring seals to prevent leakage.
Keep your PIG Mat roll close at hand with this magnetic roll holder. Attaching to any magnetic surface, keep it on the side of your tool cart or tool box to have mats ready to use at any time. Save space on shop surfaces and utilize one handed operation to clean up spills in a flash.
Professional grade gloves for the hard working DIY customers.
On pit row or in the garage, tough work requires tough equipment – and that includes your gloves.
The M-Pact 2 has been specifically manufactured to help absorb impacts by using a high-density foam padded knuckle panel in combination with a die cut EVA foam padded palm area.
ECS Tuning - VW
Aug 26, 2015 02:54 PM
ECS Tuning - VW
Aug 25, 2015 02:54 PM
ECS Tuning - VW
Aug 24, 2015 01:51 PM
ECS Tuning - VW
Aug 19, 2015 02:15 PM
