turn signals not working after LED's install.
Old Jun 2, 2013 | 07:20 AM
6t6's Avatar
6t6
6t6 is infamous around these parts
I put spyder LED's in my C2 996 and am baffled. During the install I blew fuses and finally realized one cannot hook up the side marker lights into the (these) LED'd or it will blow a fuse. So I have the brake and tail lights working but for the life of me I can't get the rear turn signals working .Fronts work but of course flash quickly due to no load from rear. I've checked every fuse in the footwell on drivers side and there are none blown. Does anyone have an idea what I check next??
Thanks in advance
Old Jun 2, 2013 | 08:44 AM
Chupacabra's Avatar
Chupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond repute
6t6, you got yourself into the wrong forum. Repost in the 996 forum or hopefully a mod will come along and move you over.
Good luck.
Old Jun 2, 2013 | 08:48 AM
SanibelSpeed's Avatar
From: Split my time between Miami, Sanibel & Woodstock, VT
SanibelSpeed has a brilliant futureSanibelSpeed has a brilliant futureSanibelSpeed has a brilliant futureSanibelSpeed has a brilliant futureSanibelSpeed has a brilliant futureSanibelSpeed has a brilliant futureSanibelSpeed has a brilliant futureSanibelSpeed has a brilliant futureSanibelSpeed has a brilliant futureSanibelSpeed has a brilliant futureSanibelSpeed has a brilliant future
I learned long ago that DIY doesn't mean "Do It Yourself" but actually means "Destroy It Yourself".
Old Jun 2, 2013 | 07:24 PM
6t6's Avatar
6t6
Originally Posted by chupacabra
6t6, you got yourself into the wrong forum. Repost in the 996 forum or hopefully a mid will come along and move you over.
Good luck.
doh!!!
cadman
Nov 13, 2025 08:57 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
