What tires do I need in the winter in Seattle?
Old Oct 5, 2013 | 06:40 PM
drspeed's Avatar
drspeed has much to be proud ofdrspeed has much to be proud ofdrspeed has much to be proud ofdrspeed has much to be proud ofdrspeed has much to be proud ofdrspeed has much to be proud ofdrspeed has much to be proud ofdrspeed has much to be proud ofdrspeed has much to be proud of
winter tires
Definitely get winters. It preserves highest performance possible.
I got pirellis and the new Michelin winters for the 20s are supposed to be much better. More money but probably worth it!
Good luck
DRP
Old Oct 14, 2013 | 09:53 AM
stirthepot's Avatar
stirthepot has a spectacular aura aboutstirthepot has a spectacular aura about
Get winter tires if driving 40 or below. Don't chance it. If you get in an accident a smart lawyer or police officer will look at the rubber and if its not recommended for the conditions you will be liable.
Stopping power with a summer tire in the cold is dramatically reduced as is adhesion particular under a emergency maneuver.
Do you really want to be cruising along at 65 mph and have to swerve or stop suddenly and then find out you can't or your car is handling drastically differently. Bad time to find out. Better to be safe than sorry.
Old Oct 14, 2013 | 11:09 PM
New991S's Avatar
New991S is infamous around these parts
Originally Posted by TTCarrera
My 991S is not my daily driver, but I did have it out 2 or 3 times in the monsoon here in Portland over the last 5 days (record rains here, as well as Seattle. Apparently, remnants of a typhoon that hit Asia 8-10 days ago).
On both city streets and on the freeway, the car was stable and solid. No sliding, skidding or any concerns. Obviously, I was sensible with the throttle, but the rain is not an issue with this car.
Hi TTCarrera -
Would you mind letting me know type/size of your winter tire set up. As I'm in Seattle, mostly worry about the wet rain as we rarely get any snow.
Some have said that I should move down to 19" and go narrower??? Any thoughts.
Thanks for your help.
Old Oct 15, 2013 | 04:34 AM
farfinator's Avatar
farfinator is infamous around these parts
1. Yes, a narrower footprint (width) tire is better in the snow.
2. Yes, tire with more pliability and sidewall, versus low profile, are better in snow, ergo and smaller rim both in diameter and width is desirable and generally recommended by manufacturers.
3. Snow tires have a different compound suitable for low temps which promotes optimum handling, summer tires are much less forgiving in "touchy" circumstances. As such, winter tires will suffer accelerated wear if not swapped out at the end of season due to the softer compound.
4. Michelins generally speaking and Alpins in particular are a great winter choice.
"Saving the money" ... always amuses when Porsche owner shares that sentiment when discussing issues of safety...Seriously? Minimally, if you want to "save" money, buy a set of year round all seasons, but trying to push a literal summer tire through seriously hostile weather, is asking for trouble, despite how many heroic tales of "overcoming the odds."
PV=nRT.
Sep 9, 2022 06:06 PM
danyoP4S
Sep 30, 2021 05:06 AM
Rguy
Apr 12, 2020 11:11 PM
AUDIRS6
11
Oct 8, 2015 12:21 PM
horsepowerfarm
Sep 10, 2015 06:09 PM
