Slight Scratch on door
Old Oct 8, 2013 | 10:47 AM
Expect212's Avatar
Expect212 is infamous around these parts
Any idea what I should do, I got a light white scratch on my door side on my Black 991 Probably from a rock while driving. Should I bring it to a detail place or bring it to an auto body place, And how much you think they would charge me?
Old Oct 8, 2013 | 11:45 AM
rnl's Avatar
rnl
rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !
It depends on the depth of the scratch. I suggest a high end body shop.
Old Oct 8, 2013 | 12:10 PM
chuckbdc's Avatar
chuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud of
I would go to a good body shop- check with your dealer. The cost would depend on the depth and length of the scratch.
Astoundingly good professional repairs without doing entire panels can be done in a couple hours of skill, science and the dark arts. Usually multistage filling and leveling of the pigment, then progressive wet sanding and polishing, then repeat with clear coat to blend.
That said, more than a few folks I know would get a whole door panel done at nX the price to achieve nirvana.
Old Oct 8, 2013 | 02:36 PM
ae911's Avatar
ae911 is a splendid one to beholdae911 is a splendid one to beholdae911 is a splendid one to beholdae911 is a splendid one to beholdae911 is a splendid one to beholdae911 is a splendid one to beholdae911 is a splendid one to behold
Completely agree... some scratches are so light that an aggressive cutting polish will sort it out. I would go to a high end detailer and body shop. You will find interesting what both would recommend. Choice at the end of the day is yours...
Old Oct 8, 2013 | 02:56 PM
yxc145's Avatar
yxc145 is infamous around these parts
I was the same way when I first got my car. For about 3 months. This will happen more and more. There is just no way you can fix every chip, every scratch. I say, if it is a light scratch that can be polish/buffed out, get it taken care of. If it requires re-painting, I don't think it is worth it.
Old Oct 8, 2013 | 04:47 PM
dyim's Avatar
dyim is infamous around these parts
Sometimes, I use my fingernail to see if it comes off.
Old Oct 8, 2013 | 06:35 PM
certified_prime's Avatar
certified_prime is a glorious beacon of lightcertified_prime is a glorious beacon of lightcertified_prime is a glorious beacon of lightcertified_prime is a glorious beacon of lightcertified_prime is a glorious beacon of lightcertified_prime is a glorious beacon of light
Try Meguires ScratchX. Worked wonders on my car for some light scratches.
Old Oct 9, 2013 | 07:22 AM
chuckbdc's Avatar
https://www.6speedonline.com/forums/...al-method.html
The post at the link above is what I had in mind. Add patience and it is the cure for scratches!
Old Sep 27, 2020 | 12:32 AM
dougcayenne's Avatar
dougcayenne has a spectacular aura aboutdougcayenne has a spectacular aura aboutdougcayenne has a spectacular aura about
LOL ... I bought the kit from ebay for $60, I also bought 3m Wrap gloss black 2080. I will use the kit as my template and cut it out. My Pan4s is 2014 now, so I lost a motivation to replace the 4 panels.Look great with wrapper.
https://www.ebay.com/itm/Windows-doo...72.m2749.l2649
Old Sep 29, 2020 | 08:35 PM
Bob Z.'s Avatar
Bob Z. is just really niceBob Z. is just really niceBob Z. is just really niceBob Z. is just really nice
It depends...pic?
Old Oct 5, 2021 | 09:47 PM
took my 2016 pan4 to bodyshop to paint the 4 panels with body color - black metalic 2 mos ago, they look fantastic for $300 cash, plus complete car details .worry free for years. Porsche took care 1 driver side in 2019 under warranty, the other 2 on the passenger start peeling. No more 3M ... The bodyshop is slow they need customers ...
Old Oct 26, 2021 | 08:37 PM
Zelig's Avatar
Zelig is infamous around these parts
I have one like that one my rear fender, You barely see it but it is through the paint to the primer and won't rust. A high end body shop my Porsche dealer uses says it would cost about 75 bucks and they will wet sand it. They also said if I traded it I won't get charged by the dealership. I have chosen to just let it be.
Anyway I would NOT use a detail shop. If you fix it go to wherever your Porsche dealer goes for bodywork.
Good luck.
Old Dec 31, 2021 | 07:31 AM
mickbiden2's Avatar
mickbiden2 is infamous around these parts
hellodear.in
teatv.ltd
gellie
NY Tri State
Apr 19, 2012 10:22 AM
forbes210
Aug 30, 2011 12:56 PM
joecmess
Jun 30, 2011 09:27 PM
yrralis1
Jul 24, 2010 11:11 AM
