Wheel offset
Wheel offset
Hi guys,
I am new here and hoping to get some help.
I am getting a set of 19" wheel as my snow tire set for my 2013 991 C2. The detail is front 19 x 8.5 ET 57 rear 19 x 11 ET 67. It looks like this is a set designed for a 997.
The offset for 991 I think is front ET 54 and rear ET 69. I was wondering if the set will fit 991 and what could go wrong?
Really appreciate your help
8.5x19 ET 54 front
11x19 ET 69 rear
3mm is only 1/8".
The front 57mm should clear the strut with a 235 tire.
Might be tight with a 245.
I'd recommend running a factory 5mm spacer (and wheel bolts) on the front to bring you to F 52mm.
Which should be better than 57mm.
I just went through all of this! Use this calculator to see what the rim/tire will look like on your car. It will provide an approximation! http://www.willtheyfit.com/
Thanks guys.
Lunarx: the 5mm spacers will bring the wheels 5mm out to ET 52. I think it will look nicer but will peformance be better? Could you elaborate. Really appreciae your help
I think you are better off with 52mm than 57mm.
Naturally the wider track will give you improved front grip.
On the other hand;
57mm can keep your tire deeper in the fender, which can be good for containing road splash in winter driving.
Also, a shorter front track may negate some overseer on slippery roads.
So there are some pros & cons to each option.
I'd pick up the spacers to have on hand.
If the wheels clear w/o spacers and the car drives well, maybe you don't need them.
However, if the tire seems too close to the strut for comfort (maintain at least a small finger width) or the steering feels lazy you can put the spacers on and be set.
On the other hand;
If you want 19s to sit flush then the offsets need to be in the mid to low 50s.
Have a 5, 7, 10mm spacer to see which fits best. A good tire shop should have those. Tires23 is a good place in the GTA.
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
993 Vendor Classifieds
Aug 18, 2015 03:55 PM
PelicanParts.com
993 Turbo Vendor Classifieds
