991 Heater problem...
Old Jan 7, 2014 | 10:27 AM
lrattner's Avatar
lrattner has a spectacular aura aboutlrattner has a spectacular aura about
I've had my car for 6 months and I have not had to use the heater until today. Since it's mostly in the 70-80's here in Florida, when the temps are in the 50's, that's freezing here.
I turned the ac off and raised the temp in the car to 80 and above and none of the air coming from any vent was warm. I remember there was mention on the forum of this kind of problem with the 991. I searched for it, but could not find the info.
Anyone else have this issue of no heat and if so, what was wrong?
Old Jan 7, 2014 | 10:58 AM
STALKER's Avatar
STALKER is a splendid one to beholdSTALKER is a splendid one to beholdSTALKER is a splendid one to beholdSTALKER is a splendid one to beholdSTALKER is a splendid one to beholdSTALKER is a splendid one to behold
I had the same issue.
There is a fix for it. I believe it's some control valve. My dealer fixed mine a few weeks back.
Old Jan 7, 2014 | 11:00 AM
PorscheCrazy's Avatar
Here is link where it was discussed if you are interested
https://www.6speedonline.com/forums/...t-no-heat.html
Old Jan 8, 2014 | 04:05 AM
19hole's Avatar
19hole has much to be proud of19hole has much to be proud of19hole has much to be proud of19hole has much to be proud of19hole has much to be proud of19hole has much to be proud of19hole has much to be proud of19hole has much to be proud of19hole has much to be proud of
It is a known issue. A control valve will need to be ordere and replaced. When this valve fails, it fails in a manner that only cold air goes to the cabin.
Old Jan 17, 2014 | 07:13 AM
plenum's Avatar
plenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant future
Anyone know if PCNA has issued a tech or service bulletin to the dealer network on this issue? I am having a no-heat problem and heading over to dealer.... would like to avoid the chase and cut to the solution if you know what i mean. My C4S is only a little more than a month old.....
Thanks!
Rockinc1
Sep 30, 2015 06:44 PM
Sep 3, 2015 04:56 PM
manfred@loma_wheels
Sep 2, 2015 11:45 AM
manfred@loma_wheels
Sep 2, 2015 11:22 AM
