DIY Carrera S Front Brake Pad Replacement
Old May 30, 2019 | 09:24 AM
  #31
Alvin Fung's Avatar
Alvin Fung is infamous around these parts
So I ordered the rear brake pads from Suncoast Porsche. They fit but have 2 metal cylinders. Did I receive incorrect ones?
Old May 30, 2019 | 10:38 AM
  #32
BradB's Avatar
BradB is a name known to allBradB is a name known to allBradB is a name known to allBradB is a name known to allBradB is a name known to allBradB is a name known to all
Those are fine. The oem style pad has those counterweights on the pad.
Old Aug 24, 2019 | 09:06 AM
  #33
pgw85706's Avatar
pgw85706 is infamous around these parts
Thanks for the writeup for the front brake pad replacement. The front calipers on my 991.1 base Carrera has a spring type clip above the wear sensor. Does it just pop off?
Old Aug 31, 2019 | 04:52 PM
  #34
arter's Avatar
arter is infamous around these parts
nope you leave it in when you change the pads. It helps hold the pads in place ( pushs them against the retaining pins).
Old May 21, 2020 | 02:30 AM
  #35
zkaleem zae's Avatar
zkaleem zae is infamous around these parts
It's easy to replace. Unplug the old one from Showbox jiofi.local.html tplinklogin the harness side. Plug in the new one and install it into the pad.
Old May 23, 2020 | 03:30 PM
  #36
Little Gator's Avatar
Little Gator is infamous around these parts
In the beginning of this DIY set of instructions, it says to put a jack stand under the rear cross member. There is a photo of the rear suspension & under structure, but it does not show the jack stand & where the proper placement of it should be. You don't mean a single jack stand under the middle of it, on the car's center line, do you? That doesn't sound like that would be safe.
Old May 31, 2020 | 04:28 PM
  #37
mtony's Avatar
mtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond repute
Place two jack stands under the rear crossmember just to the center of the suspension arm mounts.
Old Aug 16, 2021 | 02:24 PM
  #38
David Ferguson's Avatar
David Ferguson is infamous around these parts
caliper spring
Some cars have inboard and outboard pad sensors. if you had outboard sensors the cable would be held in place with that spring. you can add outboard sensors by replacing the cable with the dual sensor cable/
Old Aug 16, 2021 | 02:30 PM
  #39
Great job. I am doing mine now on my 991S, but I thought I would let you know you
I have spacers but you can see my anti seize(silver) on contact area's
applied your ant seize in the wrong location. it needs to be applied to the contact area's and nothing contacts where you put it..
wraithetc
Dec 13, 2017 08:57 AM
smistry007
Jun 16, 2016 03:18 PM
enoyskt
May 25, 2012 09:50 AM
speedoflight
Sep 8, 2010 12:12 PM
bsavino
Sep 13, 2007 02:15 PM
