Tires again....
The aggregate used in pavement varies across States and cities. Tires last a long time where I live versus where I grew up (Charlotte NC). The pavement in NC is very grippy and shreds tires. Here in San Antonio there's little grip and tires last a very long time. I'd rather have pavement like in NC, even though it means purchasing tires sooner.
Got 9.5k mi on mine. Actually liked them better than the MPSS replacements
Agree. After 2 sets of MPSS and driving both to the end, no more. The tire is not that impressive. I believe the PS2 will out perform it. At this point I'm willing to think in different directions. I like my current P Zeros. But I'm open. If Michelin ever produce a N version of the PSS, I'd consider it again. I'm under the belief N versions are different compounds, not just a rubber stamp (no pun intended).
with 17k of aging, you would not be running these at 150 mph across the Mojave anyway, so it looks far enough away from the inner sidewall that you can plug and patch it if the tread still has enough depth.
here is something shocking you should know...Americas Tire Company will plug AND patch a nail hole FREE...no charge whatsoever incl rebalancing ... no need to be a previous customer . They consider it a goodwill public service . Enjoy complimentary bottle of water while you wait.
Notwithstanding the mileage I got out of the PZero tires I replaced them with Michelins. I have noticed that the tires run cooler as evidenced by the lower running pressures at high ambient temps. They are also more comfortable less jarring than the Pirelli tires.
The roads in Pennsylvania suck and most are maintained by that paragon of corruption, the Commonwealth of Pennsylvania. They dig, patch, pave and start over again each time leaving more bumps and holes. One only has to travel south on 81 to Maryland to see an immediate improvement south of the border- same traffic volume results in vastly different existing road surface.
Were you running comfort-pressure @ partial load?
PSS dont like high pressure.
Cheeky?...that was mean man. This is my daily drive and I drive as spirited as I can in residential streets. Anyway, this morning I was able to repair the rear left and placed an order for all 4 Michelin tires. Have to wait several weeks for the Michelin rears as they are back ordered.
In reality probably 1 or 2% of the people track or drive their car's super aggressively. But the premadona's think they know it all. In reality I often wonder if these are really 15 year olds playing on their x-box pretending that they even own a car.
Most of the serious car guys I personally know in real life tend to be much more realistic, but somehow on the internet they come out of the woodwork. DDing in areas with good pavement and not necessarily terrorizing everyone in the neighborhood or highway lead to significantly longer tire tire life.
Also where you live has a great impact, I once saw a chart that indicated the "roughness" of pavement by region and in some areas it is dramatically higher. For the masses who simply drive their car like normal people... patch your minor nail holes, keep your tires while there is safe tread on them (as long as their age is reasonable) and ignore the self proclaimed "experts" who would encourage you to throw away 4 good tires because one got a small nail in the tread.. Maybe this isn't the recommendation for trackers.. but for the other 99% of DD's it is just fine..
Anyway, I am probably benefiting from a road surface which is much less abrasive than normal as here in phoenix most of the roads have been rubberized.
http://www.azdot.gov/business/enviro...vement-program
The PSS is designed to last longer than the PS2. I'd rather have the most grip I can get, especially in a 911 which has all sorts of grip issues when cornering.
the number one " expert " piece of advice to take with a major grain of salt goes something like this " I replaced the worn out *%#^ noisy OEM tire with the board recommended aftermarket SuperMcQuiets and I agree that so far , with 100 miles on them , they are SOOOOOO smooth and silent compared to the OEM "
If you replace any worn tire , with even the same tire, it will be " SOOOOOO " quiet , but what you never read is someone who , back to back same day , drives the same car on the same road with brand new set of OEM vs brand new set of that aftermarket tire .
I hear you man....
