Brake fluid moisture level tester
Old Oct 22, 2014 | 06:28 PM
ChuckJ's Avatar
ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !
My tester just arrived and I tested my system. I just changed fluid in June so I didn't expect to get a failing result. Mine read <1%. Up to <2% is just by the tester manufacturer to be ok.
The device is very easy to use and appears to work correctly. It says it is calibrated for DOT4 so that implies some level of accuracy, but the package doesn't come with a spec sheet so we don't know the accuracy. It also appears to be German which also gives me some confidence.
It is important to take the reservoir screen out before starting. Install the battery in the device and push the button on top to ensure it's working. Take the bottom cap off and expose the probes. Push the button again and when the battery light illuminates, THEN insert it in the fluid and you will get a reading within a couple seconds.
I'll be checking it over time to see if the fluid degradation is captured by the device. This cost effective tester may help limit changes to only when needed and let people know if they need to change fluid earlier than the scheduled time.
ChuckJ
Name:	Brake fluid tester.jpg
Old Oct 22, 2014 | 08:57 PM
BradB's Avatar
BradB is a name known to allBradB is a name known to allBradB is a name known to allBradB is a name known to allBradB is a name known to allBradB is a name known to all
This is very interesting. Where exactly did you source the tool?
Old Oct 23, 2014 | 05:42 AM
ChuckJ's Avatar
Purchased at Amazon for $21.95.
Amazon.com: Brake Fluid Tester - calibrated for DOT 4 brake fluids: Automotive Amazon.com: Brake Fluid Tester - calibrated for DOT 4 brake fluids: Automotive
ChuckJ
Old Oct 23, 2014 | 01:18 PM
BradB's Avatar
Thanks! I'm gonna grab one. Can't have too many tools.
Old Oct 23, 2014 | 02:50 PM
ChuckJ's Avatar
I do wonder if the reading for the reservoir will be the same as for the calipers as there isn't any circulation. It may be close enough as the moisture may migrate.
ChuckJ
Old Oct 24, 2014 | 12:07 PM
TSpyder's Avatar
TSpyder is a jewel in the roughTSpyder is a jewel in the roughTSpyder is a jewel in the roughTSpyder is a jewel in the rough
ChuckJ
That's an interesting question, ie, the homogeneity of moisture level throughout the hydraulic system. One way to check would be to get a meter reading on the first fluid out of the caliper during a flush and compare to the reading at the reservoir. Anyway, I've ordered the tester. Thanks!
Spyder
Old Oct 24, 2014 | 12:26 PM
ChuckJ's Avatar
Spyder
Yep, good idea! If you show <1 or 2% at the reservoir the difference in reading might not be critical, but as you get toward the margin it might be.
ChuckJ
Old Oct 24, 2014 | 12:42 PM
MKW's Avatar
MKW
MKW is infamous around these parts
read some of the reviews on Amazon ....most seem satisfied with this Taiwanese product which comes with no known manufacturer or documentation of accuracy , but a few tested it on brand new unopened bottles of DOT 4 and got " red" readings, so one wonders what the specificity of this device is..if it is only 80% ....hmmmm
no one knows , so YMMV
I prefer to just change fluid every two years on all my cars irrespective of miles , since I don't track any of them and none ever see more than 8k miles put on annually and flushes are relatively cheap
Old Oct 24, 2014 | 05:10 PM
ChuckJ's Avatar
There is a sequence (which I outlined above) and if you don't follow it, you do get incorrect readings.
ChuckJ
Rguy
Apr 12, 2020 11:11 PM
Feelgood MD
Mar 24, 2016 09:35 AM
ECS Tuning - VW
Sep 2, 2015 12:58 PM
holmesatx
Sep 2, 2015 11:32 AM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
