Need help on a ongoing exhaust upgrade
Old Nov 25, 2014 | 03:13 PM
wanderfalke's Avatar
wanderfalke is infamous around these parts
I have ordered a list of parts to upgrade my 2013 C4s exhaust to a sport exhaust. I did not include the tips. I just got a call from the dealer saying they could not reuse my tips and want a addition $1600 to use the kit tips . This not the case right?
Old Nov 25, 2014 | 03:26 PM
drcollie's Avatar
drcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond repute
Not true. If you have an "S", you have the same tips that are used on the factory Sport Exhaust, and even if you needed a set, they're not $ 1,600. I've played around so many times with 991S tips I can do them blindfolded now.....the tips are held one with one clamping female TORX screw - only the base 991 has a different exhaust on it. He's probably confusing it with that.
Old Nov 25, 2014 | 03:27 PM
STG991's Avatar
STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !
You mean $600 for new tips?
If you have the S model you CAN use the tips. They are identical. I got duped into ordering some and now have an extra set!
If you have the base Carrera, you need the new tips.
Old Nov 25, 2014 | 03:41 PM
911cv's Avatar
911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold
Like the other gents said, you don't need new tips. I just installed the PSE on my car and the dealer reused my tips.
Old Nov 25, 2014 | 04:10 PM
THANK YOU! I do have the CS4 I think it should not make a difference. Which set did you keep?
Old Nov 25, 2014 | 04:14 PM
STG991's Avatar
I kept the old ones. The clueless dealer told me I needed new ones, only to see they were the exact same ones after I got the old parts back.
I would have saved like $600 otherwise.
They usually don't know what they're talking about unfortunately!
Old Nov 25, 2014 | 04:15 PM
STG991's Avatar
Are you getting a button too?
Did you order the parts individually minus the tips .
Old Nov 25, 2014 | 04:16 PM
STG991's Avatar
The dealer ordered the whole kit including tips. You can order everything individually without the tips and save $$$
Old Nov 25, 2014 | 04:44 PM
Squires9914s's Avatar
Squires9914s is infamous around these parts
Can we order the PSE without the tips from suncoast to save some money ?
Old Nov 25, 2014 | 04:47 PM
STG991's Avatar
I'm sure. Don't see why not? All the individual pieces have part numbers. Call Ryan over there.
Old Nov 25, 2014 | 05:38 PM
Yes I am.
Old Nov 25, 2014 | 06:13 PM
Here is the situation. They will sell you the parts for the PSE without the exhaust tips but they will not sell you the tips without the kit. So I ask what happens when the tips are damaged in accident. Porsche wants a picture of damage and will sell them to you for $600 each. They really want control of the replacement exhaust. It is my opinion that I already paid for them once and two grand for a muffler,valves,and switch is enough.
Old Nov 25, 2014 | 06:18 PM
STG991's Avatar
That's the most ridiculous thing I've ever heard.
You don't need the tips anyway, so screw them.
Just tell the idiots to put your current tips on the new muffler. Tell them if they don't fit you'll buy the new ones. I'm telling you they're the exact same thing. Unless there are like 1 mm different or something. I highly doubt it. Side-by-side, the tips they came on my non-PSE looked like the exact same ones as the ones they put on.
Old Nov 25, 2014 | 06:29 PM
Hope this helps, https://www.6speedonline.com/forums/...1&d=1416965164
Name:	bid for PSE.jpg
