Will Hankook Ventrus v12 evo2 fit rears?
Need to replace tires. Considering Hankook evo2's. They make exact size for front but not exact size for rear.
Stock rear is 295/30/20 with 101y load rating. Hankook does not make that size in Evo2 but does make. 285/30/20 with 99 load rating. I know the Hankook will be 10 mm narrower, but does anyone know if the load rating makes the tire unacceptable for a basic daily driver?
Reducing the load rating is not good. Even for a daily driver, you could get into an emergency situation where a tire could fail due to an extreme maneuver. Also I don't know what position your insurance company might take if an accident was the result of a lower rated tire. You have a $100K+ car, it's worth getting the correct tires.
Load rating on such a light car?
Hardly a concern.
Still, I would not go narrower on the rear tire.
The V12 is not that special to be worth downsizing for.
The PZero are a great tire, so not too much to gain by changing to anything else.
PSS do last longer, but not so sure they perform better.
Hardly a concern.
Load rating on such a light car? Hardly a concern.
Every size tire has a different load rating. There are multiple rear tire sizes used on the 991 and all are able to handle the load.
285-35-19, 295-30-20, 305-30-20
Its common sense that if bigger heavier cars (able to carry 4+ passengers and cargo) use 285-30-20 tires then a light 991 wont have a load problem.
Porsche picked the tire sizes for handling balance and there is plenty of load reserve in those tire sizes.
Feel free to check the weight capacity of that load rating and you will see it is more than ample.
However, since 991 is tail happy I advise not downsizing the rear tire (for handling balance reasons).
As for sound engineering, you have to admit 20" tires were chosen more for looks than valid engineering reasons.
Its common sense that if bigger heavier cars (able to carry 4+ passengers and cargo) use 285-30-20 tires then a light 991 won't have a load problem.
Yep. No offence but if you really need to save the $300 or whatever you shouldn't be driving a 911 in the first place. The Ventus V12 Evo is a fine tire (I had a set on a BMW in the past) but not something I'd consider for a Porsche.
First off the Hankook Ventus tire is garbage next to the PZero or the Mich PSS. Not to mention it is a terrible idea to mix tire/brands on a car.
Second, a 285/30/20 tire max recommended width for the wheel is 10.5". You are just asking for issues...
To be frank I would go on Ebay looking for a used tire with 6 to 7/32nds left on the tire at $150.00 a pop before I put a set o f Ventus tires on my 991.
Dave
Dave
Would you use them on your 991S? I had them as well and the sidewall is ridiculously soft. I was in a spot as I am running M3 GTS sizes on my M3 with the ZCP package (255/35/19 and 285/30/19). No Mich PSS in this size so I tried a multitude of tire options in these sizes. I found the Hankooks equal or in fact a tad less than the Nitto Invos. They are OK for a street tire but would never own again on my own cars.
This is forgetting the fact that the tire size the OP listed is not recommended by the manufacturer for the width of the wheel and mixing tire brands front and rear.
Nah, I agree with you. If they don't have a compatible size based on Porsche reco's then I won't be taking any chances on my 991S either.
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
