question for wheel offset experts
Old Jan 13, 2015 | 08:29 PM
akbjr's Avatar
akbjr is infamous around these partsakbjr is infamous around these parts
I am in the process of ordering a C4S and am between the carrera S wheel and the sport techno wheel. I noticed that the width of the rear wheel is different and that there is no spacer offered with the sport techno wheel. Does this mean that the amount of the wheel well filled by a carrera s wheel WITH spacer would be equal to that of the sport techno wheel alone?
Any one with photos of the sport techno wheel in black and silver combo would be very helpful.....
thanks.
Old Jan 13, 2015 | 11:15 PM
TR991's Avatar
TR991 has a spectacular aura aboutTR991 has a spectacular aura about
The AWD 911 is almost two inches wider than the 2WD version.
The Sport Techno wheels designed for the 4 are 11.5" wide (+48 rear offset). Because of the additional vehicle width, the offset is adjusted and no spacer is required.
Typically, if wheels are the same width, but different offsets, a higher offset will make the wheel "sink into" the car, towards the struts while a lower offset will make them "stick out" from the fender.
Short answer: Yes, the Sport Techno wheels designed for AWD 991s will have a similar appearance as the Carrera S wheels do on a 2WD 991.
Hope this helps.
*data and numbers were pulled from Suncoast parts (wheel width and offset) and Porsche website (vehicle width).
Old Jan 14, 2015 | 07:10 AM
Vise's Avatar
Vise is infamous around these parts
Originally Posted by TyroneR
The Carrera S wheels are 9.5" wide (+45 rear offset) and designed for narrower 2WD vehicles.
Um, this is not correct. Direct from Suncoast's site... the offsets differ due to the wide body on the 4/4S. To answer the original question my understanding is yes, the wider Sport Techno wheels + offset difference should roughly equal the Carrera S + space in terms of fitment.
Carrera S wheel/tire package:
Front - 8.5 x 20 ET51 - 245/35 ZR 20
Rear - 11 x 20 ET70 - 295/30 ZR 20
Size: Carrera 4/Carrera 4S
Rear - 11 x 20 ET52 - 305/30 ZR 20
Sport Techno wheel/tire package:
Front - 9 x 20 ET51 - 245/35 ZR 20
Rear - 11.5 x 20 ET68 - 305/30 ZR 20
Rear - 11.5 x 20 ET48 - 305/30 ZR 20
Old Jan 14, 2015 | 09:07 AM
akbjr's Avatar
thank you very much.
Old Jan 14, 2015 | 07:21 PM
TR991's Avatar
Thanks for the correction, I cut down the text to not confuse anyone who reads it in the future. -ty
Old Jan 15, 2015 | 11:01 AM
chuckbdc's Avatar
chuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud of
The Carrera S rear wheels for the 4WD models has a greater offset than the ones for the RWD models. Am continuously envious.
Old Jan 15, 2015 | 11:06 AM
Robsc2s's Avatar
Robsc2s is a splendid one to beholdRobsc2s is a splendid one to beholdRobsc2s is a splendid one to beholdRobsc2s is a splendid one to beholdRobsc2s is a splendid one to beholdRobsc2s is a splendid one to beholdRobsc2s is a splendid one to behold
FWIW- try willtheyfit.com for comparison
Aug 21, 2015 09:56 AM
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
Aug 18, 2015 03:51 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
