keeping bluetooth audio connected?
Old Nov 18, 2015 | 03:02 PM
trovan's Avatar
trovan is just really nicetrovan is just really nicetrovan is just really nicetrovan is just really nice
I am grateful that my 991 has bluetooth audio. However, every time I come back to the car, it plays FM radio at high volume, instead of the bluetooth audio before I turned off the engine. Other cars such as BMW is able to keep the bluetooth audio as a selection, anyone has figured out anyway to do this? thanks.
Old Nov 18, 2015 | 07:41 PM
PorscheCrazy's Avatar
I use Jukebox and every time I come back to the car, Jukebox comes on. What you need to do is set your fob to auto memorize your settings each time you lock your door with your fob. Go into Settings on the MFD, and in one of the menus there is an Auto Memory setting. Check that box.
Old Nov 18, 2015 | 08:35 PM
trovan's Avatar
Thanks. Will give it a try
Old Nov 19, 2015 | 11:01 AM
Rapture1's Avatar
Rapture1 is infamous around these parts
I've tried many times to have the car remember to connect to the IPod (phone) when I start up. I have never had any success. I think it needs to be a connected source when it starts in order to remember, which Bluetooth and in my case a USB connected phone are not for a minute or so after start up. I had even tried to have it remember the Aux connection but that did not work either.
Now I just turn the volume down before turning off the car.
If you have better luck please share.
Old Nov 19, 2015 | 01:43 PM
These are good and valid points, but think that if the PCM can automatically connect with your phone automatically via bluetooth, it can connect with the music too, no? Maybe the caveat with music is that the music may need to be on before you start the car in order for the car to get the BT signal?
_____________________________________
Well, I just tried it. Looks like my theory is wrong - sorry. Seems that you will need to push the button to go to Aux BT and PCM will not automatically do it.
Old Nov 19, 2015 | 07:15 PM
Samp's Avatar
Samp is infamous around these parts
To compensate for the volume level when going to FM you can adjust the difference for volume to compensate for the difference. I think it is in the sound section.
Of course that won't solve the going to FM but will help with the column issue.
nsogiba
Nov 30, 2015 07:24 AM
MadWhip
Oct 22, 2015 09:21 AM
carlosC4S
Cayenne 958
Oct 21, 2015 10:35 AM
ManuelCarrillo3
Charity Notices/Events
Oct 20, 2015 02:03 PM
