Suggestions on how to raise idle speed?
Old Aug 4, 2016 | 11:56 PM
MichaelB1969's Avatar
MichaelB1969 is infamous around these parts
Hi everyone, my idle is around 600rpm when in standard mode, and 800rpm when the sport button is activated. I have had both the Sharkwerks and AWE center muffler bypass exhausts installed, and with both I experience vibration at the 600rpm idle speed...which goes away when I hit the sport button and the idle bumps up to 800rpm.
Does anyone know of a reasonably priced option to modify the ECU to raise the non-sport mode idle from 600rpm to 800rpm?
Thanks,
Mike
Old Aug 5, 2016 | 02:37 PM
combatninja's Avatar
combatninja is infamous around these parts
I imagine that one of the tuners like Cobb could make you a custom tune that could do just that. You'd probably gain a healthy dose of power too coupled with your exhaust modifications. Contact the nearest Cobb tuner in your area and ask them.
Old Aug 6, 2016 | 05:50 PM
BradB's Avatar
BradB is a name known to allBradB is a name known to allBradB is a name known to allBradB is a name known to allBradB is a name known to allBradB is a name known to all
Boy, sometimes I miss the good ole days.
Old Aug 7, 2016 | 06:34 AM
He's been down that road already ^^^. Multiple visits to the installer, tech support from the vendor. There is no fix for him except to keep the car always in SPORT mode so that the idle is a couple hundred rpm higher.
I see no reason why a Cobb ProTuner could not program your idle in default mode to be a few hundred rpm higher. Have you asked them yet?
Old Aug 8, 2016 | 09:38 PM
Good advice. I'll send an email to Cobb and see what they say. Thanks.
Josh/AWE
Mar 20, 2017 03:07 PM
AMG-ETR
Jul 20, 2003 09:35 PM
