15 GTS engine grille and 17 engine grille compatibility
Old Dec 26, 2016 | 12:17 PM
solrac6262's Avatar
solrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to all
Hello All,
are the 991.1 and .2 grilles compatible?
I was just curious if the GTS grille can be used on the 991.2 since the .2 have the design for air flow..?
thanks
Old Dec 26, 2016 | 02:37 PM
chance6's Avatar
chance6 is a splendid one to beholdchance6 is a splendid one to beholdchance6 is a splendid one to beholdchance6 is a splendid one to beholdchance6 is a splendid one to beholdchance6 is a splendid one to behold
I wouldn't put the GTS grille on the 991.2 since that whole intake is revised in the 2nd Gen.
Old Dec 27, 2016 | 02:48 PM
solrac6262's Avatar
thanks for the info
Old Dec 27, 2016 | 06:49 PM
chance6's Avatar
Also the GTS is a wider rear end and I'm not sure if it would even fit correctly on a narrow-body 991.2.
Old Dec 27, 2016 | 10:31 PM
solrac6262's Avatar
fits on the 991.1 not sure why should not fit, that area looks to me the same
Old Dec 28, 2016 | 03:27 AM
PorscheCrazy's Avatar
I note sure it would fit. Pretty sure the .2 tail lights will not fit the .1 bumper - different design opening.
