Technical wheel/tire question
Old May 30, 2017 | 06:36 PM
murox's Avatar
murox has a spectacular aura aboutmurox has a spectacular aura aboutmurox has a spectacular aura about
I have a '13 C2S (narrow body) and I'm running wide-body offset OEM wheels on the rear with 305/30-20 tires. I like the aggressive look of the wide-body wheels on my C2S, but the Pirelli 305s are a bit bloated on the wheel, and stick out slightly from the fender. Its time for new tires, and I'm deciding between the Michelin Pilot Super Sports and the Bridgestone Potenza S-04 Pole Positions, which are about $300 cheaper, but the Tire Rack guy I spoke to was raving about them for non-track use.
Anyway, I'm thinking about going down to 295s for a more flush fitment within the fender and I'm looking for feedback on both the tire size, and which tire I should select.
Thanks.
Old May 31, 2017 | 10:09 AM
Whoddoo's Avatar
Whoddoo is infamous around these parts
Take a look at the Michelin Pilot Sport 4S
Just put the new Michelin Pilot Sport 4S tires on my 2014 C2S. Even though I bumped up the rear to the 305 vs. the 295 Pirelli I ended up going from a 5mm spacer to a 15mm spacer on the rear and the fit is perfect. Check out the new 4S's which have been getting great reviews over the Pilot Super Sports. Personal opinion after 2 months is a great improvement over the Pirelli's.
Old Jun 4, 2017 | 07:55 AM
RON1X's Avatar
RON1X is infamous around these partsRON1X is infamous around these parts
I also recently went from the 295 Pirelli to the 305 Michelin Pilot Sport 4S. I much prefer the 305 look. I'm also actually looking into spacers for the front and rear as well to get less gap between the fender and tire.
I'm extremely happy with the Michelin 4S tires. I did not like the OEM Pirellis...
Old Jun 11, 2017 | 06:53 PM
murox's Avatar
Ok, perhaps adding images will help. This is my current setup: C2S running wide-body offset OEM wheels with 305s on rear. I bought the wide-body wheels because I like the more aggressive stance it gives the car, but I can decide if the 305s add a little too much "beef" to the rear, and I'm considering going down to 295s to make it more flush with the wheel well.
Thoughts?
Old Jun 11, 2017 | 07:42 PM
eldertec's Avatar
eldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to behold
Looks Great!
Stay with them
Old Jun 11, 2017 | 08:52 PM
r11rs's Avatar
r11rs is infamous around these parts
Looks like the rears are really sticking out?! Are you getting lots of kick back on the bumper and/or sideskirts?
Old Jun 12, 2017 | 05:47 AM
murox's Avatar
No, not much if at all.
Old Jun 22, 2017 | 03:56 PM
scatkins's Avatar
scatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond repute
Thanks.
I guess I don't know what "narrow" and "wide" body ofset OEM wheels are.. First I've heard the term. I've got a C2S ('14) which I think you are calling "narrow" as opposed to a C4x?...
In any case I've got P-Zero 305s on the rear that came with my Sport techno's.. I do realize they are apparently wider than standard because everytime I order new tires from tire-rack, they never come up as a standard size for make/model.
In any case, I think they look about right on my C2S.. Certainly don't look too big.
Old Jun 25, 2017 | 07:56 PM
murox's Avatar
You've never heard the terms "narrow body" and "wide body" 911s? The C2S is narrower than the C4S, turbo and GT3, hence the name narrow body. There is no such thing as narrow body or wide body offset wheels, but rather wheels that were OEM from either a narrow body car or a wide body car.
Regardless, you have 305s on your C2S OEM wheels, which isn't the question I was asking. I'm running 305s on C4S offset wheels, which have a 59mm offset as opposed to the 65mm offset you have.
Old Jun 27, 2017 | 05:31 AM
porsche42's Avatar
porsche42 is a splendid one to beholdporsche42 is a splendid one to beholdporsche42 is a splendid one to beholdporsche42 is a splendid one to beholdporsche42 is a splendid one to beholdporsche42 is a splendid one to beholdporsche42 is a splendid one to behold
I like the look, the tire looks almost flush to the wheel. I'm surprised you don't get any kickback from rocks on the rear fender. I would go with the Michelin 4s just put them on my car. Great tires and rave reviews from tire rack.
