993 Turbo This community is about the last air cooled twin turbocharged Porsche 911. Model year 1996 - 1997. Also inclusive in this forum is talk on the final 182 Porsche 911 Turbos built in 1997 known as the Turbo S.
Motec adapter harness M600
Old May 28, 2010 | 10:23 AM
IMA Motorsport's Avatar
IMA Motorsport is infamous around these partsIMA Motorsport is infamous around these parts
Just finished an adapter harness for a 95 993 chassis that we had converted with a turbo engine. While it stayed stock for many years we added some Garrett turbochargers to upgrade response and power. Considering all the hassles that tuning the factory ecu brings along I talked our customer to go the Motec route, keeping the factory harness intact.
I located and purchased the ecu header connector for the 88 pin ecu and made an adapter harness that plugs into the factory harness and into an M600 Motec ecu. I have been driving the car now for several weeks and it is awesome. All the controls at my fingertips and not in the hands of a who knows who tuner, that can actually damage the ecu doing the job. Also any upgrades no problem, just plug laptop in and away you go. If you need emmissions fo your state, unplug Motec and plug your factory ecu go through test and reverse it again.
A basic map ready to go would make it a plug and play. If you want to have options like electronic boost control, no problem. A switch on the dash with some added wires into the ecu voila! boost control!
The engine starts and runs like a factory car. It came out very nice.
What have you all done in the past?
Cheers
wrs
Nov 17, 2016 06:53 AM
Glasgo
Nov 30, 2015 02:37 PM
Pcar416
Nov 22, 2015 12:49 PM
Needsdecaf
Cayenne 958
10
Oct 12, 2015 03:05 AM
pwdrhound
Sep 25, 2015 05:25 PM
