993 Turbo This community is about the last air cooled twin turbocharged Porsche 911. Model year 1996 - 1997. Also inclusive in this forum is talk on the final 182 Porsche 911 Turbos built in 1997 known as the Turbo S.
Car will not start....no spark????
Old Jun 20, 2011 | 11:54 PM
sandyclinic's Avatar
sandyclinic is infamous around these parts
Car has been in the shop for a month for some minor body repairs(paint chips, front clip paint job etc)...drove to beach (Oregon coast)...stopped on the way back and very difficult to start...finally got it going and now it will not start at all...replaced the fuel pump relay to no avail...any ideas????....Steve C ..97 993TT
Old Jun 21, 2011 | 11:53 AM
Slik560's Avatar
Slik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond repute
I wish I knew enough to help, but I don't. It might be time to head over to www.rennlist.org or the Pelican Parts forums to seek the truth. Good luck. Might the cam timing be off? (WAG)
Old Jul 4, 2011 | 01:03 AM
budge96's Avatar
budge96 is infamous around these parts
97 993 TT no spark
Actually I'm having a similar problem ,since my car has been back from the shop it's been unfortuneatly in a damp garage and to compound the situation the immobilizer light has begun to blink intermittently.
I thought it was related to an undercharged battery but that doesn't appear to be the case.
I will shortly remove the alarm brain and try and determine if that has
moisture or some problem preventing it from cycling out correctly.
I have changed the immobilizer battery already ,maybe you could try that.
This is the first time something like this has occured but it is 15 years old at this point..thanks Bert
Old Jul 10, 2011 | 08:46 PM
budge96's Avatar
Turned out to be the battery after all..fresh sealed oversize unit did the trick !
started right away like nothing happened..alot to be said for an undercharged or flat battery, caused all kinds of electronic havoc,doors not opening,alarm failing to
cancel etc..
And to be candid factory trickle charger may have helped burn battery cells...Bert
Old Jul 11, 2011 | 07:08 AM
DM993tt's Avatar
DM993tt is infamous around these parts
try a new DME relay.
Old Jul 11, 2011 | 05:08 PM
JoeL.'s Avatar
JoeL. is infamous around these parts
Does it just crank and not fire?
Old Aug 25, 2011 | 08:28 PM
jayster's Avatar
jayster is infamous around these parts
Speed sensor anyone ( after DME relay of course)!
COBB Tuning
Jan 1, 2025 09:02 AM
PorscheEnthusiast
Nov 13, 2015 02:23 PM
gulf gt
Aug 27, 2015 10:27 AM
Aug 21, 2015 09:56 AM
