993 Last generation normally aspirated aircooled Porsche 911. Community includes the C2, C2s, C4, Targa, C4s and cabriolet discussion.
Loose wire in Steering wheel?
Old May 21, 2008 | 09:41 PM
jvmax's Avatar
jvmax is infamous around these parts
ok, I have a 1997 993 with 63k miles. Just recently I noticed when the car is on, the horn is very sensitive--it goes off if I slightly touch it. Also, when coming to a stop, if I stop too hard the horn goes off. Any ideas, my guess is a loose ground wire.
John
Old May 22, 2008 | 06:12 AM
ez_777's Avatar
ez_777 is infamous around these parts
You are experiencing 993 horn pad failure. It is not an uncommon problem. There are four rubber grommets that hold the horn pad retaining ring to the steering wheel base. Those grommets give up over time. Some have replaced their grommets, some have replaced the whole part.
In my case my mechanic was able to adjust the contacts somehow to make it slightly less sensitive.
Search on Rennlist in the 993 Forum for "Steering Wheel Horn Retaining Frame" and you'll find a DIY on using slices of plastic tubing to fashion spacers/grommets.
http://forums.rennlist.com/rennforum...d.php?t=186232
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
STAGGERED M3
Sep 11, 2015 12:00 AM
no1joey
Sep 2, 2015 12:32 AM
pwdrhound
Aug 20, 2015 05:54 AM
