993 Last generation normally aspirated aircooled Porsche 911. Community includes the C2, C2s, C4, Targa, C4s and cabriolet discussion.
Shifter came loose - How to fix?
Old Aug 12, 2013 | 03:06 PM
mrtexasfreedom's Avatar
mrtexasfreedom is a jewel in the roughmrtexasfreedom is a jewel in the roughmrtexasfreedom is a jewel in the rough
1996 993 Question:
My stick shift came loose the other day. I can kinda get into most gears, but there's no leverage to get it over to reverse. If I pull directly up on the shifter, it moves four or more inches.
I had my mechanic come by and he removed the sock and trim work and sure enough, the thing just isn't attached anywhere. The rod that goes to the transmission is still connected, but that's the only thing!
What do I need to attach this shifter to the base? My mechanic said he thought it used a bushing or grommet. I haven't looked that closely. I searched the forums here for 'loose shifter' and a few other variations, but haven't found any useful threads.
thanks in advance,
mtf
Last edited by mrtexasfreedom; Aug 12, 2013 at 03:07 PM. Reason: adding year and model
Old Aug 13, 2013 | 12:45 PM
As I've researched this more closely, it looks like I need a shifter guide tube bushing. Any confirmation on the part number would be appreciated. It seems like it's loose on the end of the shift guide tube closer to the transmission, not the end that's closest to the dash. I checked Pelican parts for a diagram, but they seem to only show what looks like a bushing for the end of the shifter tube closest to the dash.
Bad pic of my own shifter showing the open space leading back to the engine / transmission:
Old Aug 14, 2013 | 08:47 AM
ECS Tuning - Porsche's Avatar
I would think along with the bushing you would also need the circlip. I suspect you need more then just those items from the sound of it, but without more pictures or looking at your shifter, it's impossible to say. For more information on the bushing and circlip Click Here.
Old Aug 19, 2013 | 08:34 PM
BradB's Avatar
BradB is a name known to allBradB is a name known to allBradB is a name known to allBradB is a name known to allBradB is a name known to allBradB is a name known to all
Be sure to replace the nylon cup bushings while you are in there. Those are the ones that normally go bad.
Old Sep 23, 2013 | 04:15 PM
Can you provide a part number? Which part is this?
Appreciatively,
mtf
Old Sep 23, 2013 | 04:16 PM
I followed that link and see the reference to the circlip. Is the "SHIFT TUBE GUIDE" the rubber bushing for the end, or is it the tube itself?
thanks!
mtf
Old Sep 24, 2013 | 09:05 AM
thanks!
mtf
The Shift Tube Guide in the link is just the rubber bushing.
Old Sep 24, 2013 | 10:34 AM
Thanks for the clarification. I just ordered the two parts from ECS.
Appreciatively,
mtf
Old Sep 24, 2013 | 03:10 PM
Appreciatively,
mtf
Thank you for the support. Let us know if you need anything else or have any trouble.
mantruck
Feb 19, 2016 05:23 PM
Kai@ELITEMS
997 Vendor Classifieds
Nov 25, 2015 06:32 AM
bongnation
Sep 25, 2015 02:58 PM
fjwheeler
Sep 19, 2015 10:56 AM
Greehn
Sep 17, 2015 03:15 PM
