Bailey Diverter Valves
Old May 11, 2004 | 03:04 AM
Greyghost's Avatar
Greyghost is infamous around these parts
Who has the best deal on these? Group buy?
Old May 11, 2004 | 03:09 AM
Weazel's Avatar
Weazel is infamous around these parts
You should check out my post on the HKS SSQV.
Old May 11, 2004 | 03:12 AM
AeroTT's Avatar
AeroTT is infamous around these parts
I got mine from AWE
Josh/AWE's Avatar
grayghost-
AWE Tuning is the U.S. Importer of the Bailey Valves.
Bailey DV's from AWE Tuning
Old May 11, 2004 | 03:16 AM
Josh/AWE's Avatar
How does the Motronic react to the BOV's? Are there any issues of the MAF detecting the loss?
We have been trying to run a BOV since 1997 on Bosch Motronic cars. We could not seem to keep them from always running rich.
Old May 11, 2004 | 03:19 AM
Greyghost's Avatar
Is there a 6SpeedOnline reduced rate?
Old May 11, 2004 | 03:28 AM
Weazel's Avatar
Mike,
Check out my write up on the HKS SSQV.
https://www.6speedonline.com/forums/...&threadid=9828
This is a direct replacement for the 2 diverter valves on the 996TT. We have had no problems with our at all.
Old May 11, 2004 | 03:42 AM
Josh/AWE's Avatar
The dyno graphs don't really tell me much.
Have you done any datalogs of the long term fuel trim?
Old May 11, 2004 | 05:19 AM
Dock (Atlanta)'s Avatar
Dock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really nice
Are your DV's making noise?
Old May 11, 2004 | 05:36 AM
sharkster's Avatar
Mine Bailey's started to Hmph.. might be the DV hose tho...
Old May 11, 2004 | 05:57 AM
Greyghost's Avatar
I just ordered a pair of Baileys diverter valves from Mike at AWE tuning. What a nice guy... thanks Mike.
Britt
Old May 11, 2004 | 06:33 AM
Weazel's Avatar
It's not that. The actual piece is that of an HKS SSQV blowoff valve. www.hksusa.com
The way we designed the use for the blowoff valve was to recirculate it back into the intake. We have had no idle problems with this piece whatsoever. We actually got better response with this unit over the stock diverter valves. We have not tested this unit over any other companies that offer diverter valves for the 996TT.
Originally posted by Ruiner
HKS SSQV (recirculated back into inake)
It seems that you and he are getting twisted on the lingo. You are venting back into the intake (diverting) whereas a true "blow off" valve would vent to the atmosphere. You are calling your setup a "blow off valve" (which it is up until you add the recirculating connect to it), but it is really a diverter valve setup. They are the same tool, but only differ in where the excess air goes.
The setup you have is technically a diverter valve because it isn't losing the excess air into the atmosphere. The problem with doing that on a MAF setup is that you run rich at shifts and you sometimes get odd idle conditions. He was wondering if you had solved the problem of running a true BOV that vents to the atmosphere.
Old May 11, 2004 | 06:57 AM
Josh/AWE's Avatar
What about the long term fuel trim?
This is a sure fire way to tell if the unit is working properly or will eventually cause a rich fuel condition.
I'm not too concerned with full throttle. I'm more curious about the part throttle.
Old May 11, 2004 | 07:02 AM
Josh/AWE's Avatar
Britt
Thanks again for your order. It was a pleasure talking to you.
Old May 11, 2004 | 07:06 AM
Josh/AWE's Avatar
Alex-
FYI. The valves have a lifetime warranty.
