12" wheel clearance - differences between 996gt2 and 996tt
Old Oct 1, 2007 | 11:40 PM
FlyYellow's Avatar
FlyYellow is infamous around these partsFlyYellow is infamous around these parts
i'm trying to get some information on the difference with clearance between a 996gt2 and 996tt. i'm trying to get a 12" rim to fit (19x12et51). I understand that the stock wheel is a 18x12et45, so i would have thought that if you space it out 6 mm it would be identically spaced. i also have a JIC cross coilover setup on the car (which should create a little extra room).
any thoughts about whether such a wheel would fit?
what are the suspension differences that would effect clearance between a 996tt and a 996gt2?
thanks kindly.
Cheers,
Boris
Old Oct 2, 2007 | 06:51 AM
maxwell's Avatar
maxwell is a jewel in the roughmaxwell is a jewel in the roughmaxwell is a jewel in the rough
You can run a 12" wheel on the turbo. The problem shows up if you're running your car extremely low, you may rub the fender when the suspension compresses. The simple fix for that is rolling the rear fenders. The fronts come rolled from the factory.
Old Oct 2, 2007 | 06:57 AM
Harold's Avatar
Harold has much to be proud ofHarold has much to be proud ofHarold has much to be proud ofHarold has much to be proud ofHarold has much to be proud ofHarold has much to be proud ofHarold has much to be proud ofHarold has much to be proud ofHarold has much to be proud ofHarold has much to be proud of
You may also find rubbing on the inner plastic liner- I have basically worn a hole on the inner wheel side near the rear of the car.
Old Oct 2, 2007 | 07:53 AM
FlyYellow's Avatar
what offsts do you guys run on the rear with 12's?
Old Oct 2, 2007 | 11:54 AM
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
I'd be careful with that, I hear this is an easy way to cause a fire for track guys.
Chris Green@USP
997 Turbo Vendor Classifieds
Jan 28, 2016 02:22 PM
Chris Green@USP
996 Turbo Vendor Classifieds
Aug 20, 2015 11:30 AM
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
