rwd or awd on turbos w 800hp
My maggied Z06, with a conservative 475rwhp with meth, would spin the 315 Falken Azenis on the parkway at 60mph in the DRY...perfect daily-driver if you ask me. But 600/700/800hp is just for bench racing or bragging rights, or...and let me spit the bile from my mouth before I say this..." roll-ons "....pthew...As many have said before, having 800hp and USING 800hp is another story. And for most people who don't have hours on a track, MOST PEOPLE, anything over 500rwhp just puts them "four-off" sooner.
Be safe,
TomK
The maggie was pushing 7.5-8lbs of boost...any highr would be pushing it for roadcourse use. And the meth was used to eliminate heat-soak on the roadcourse...intake temps went from 140degs to ambient, or under ambient. There's no intercooler in the world that can reduce intake temps as well as meth/water....none. The vapor in teh combustion chamber also does wonders for supressing detonation, allowing more boost/timing than would be allowed with pump gas. The meth also cleans the combustion chamber, valves, pistons.
I could have pullied the car up to 550rwhp, but to tell the truth...it wouldn't help me get around a roadcourse any faster. Having 475rwtq at 3200rpm, 400rwtq at 2500rpm, was a handful and I didn't want to run r-comps all the time. Keep in mind, the roots-supercharger was instant response...no lag...so the throttle needed VERY careful application in the turns. For anything other than the straights, a stock Z06 would have been easier to drive fast, as USING the power or being able to use the power is another story...you dig?
And meth...it's like running racegas all the time, but with 93 in the tank. Really, imagine NO HEATSOAK...ever. I've since sold that car for an '06 STI and currently run meth/water on that....great results, too. I would never have a forced-induction car without meth/water...for many reasons.
Be good,
TomK
With the right tires, RWD TT's with big power hook extremely well on the street. Far better than front-engine, RWD cars do. My 700 rwhp Supra on BFG DR's hooked nothing like my RWD 996TT does.
I drive my car at 800+ rwhp on the street all of the time. And I drive her HARD...from dead stops and from slow or fast rolls. She hooks wonderfully.
Would I recommend that most people with modified TT's convert their cars to RWD? No. Absolutely not.
Would I have my car any other way? No. Absolutely not.
And I'd be willing to bet that you never used more than 300rwhp on that day...
Be safe,
TomK
Be safe,
TomK
Big difference in being able to get the power down with an AWD Porsche turbo with all the weight over the rear tires vs a front engine Corvette.
Now for the street I could use more power, as I am already used to the GT700. It would be ideal to just have a track setting at 600 rwhp and a street setting (with some more work to my car) at 900 rwhp!
That would be fun!
A great idea...and yes, that sounds like some real fun!!!
900 HP street setting.?.... I thought I was bad!
Anyone use an eboost 2 and switch to external wastgates???? You can then set boost per gear(1st-6th) and rpm!!! I love this feature on mine(Chevelle). You can have your cake and eat it too! It allows you to set max boost in each gear so the power is useable.
I need to get a TT P-car and start modding, this is driving me nuts!!
Drag radials are not made for handling. They're made for hooking in a straight line. If you want a tire that does both...r-compounds are the optimal choice.
IRT to your Gallardo, any car that's converted from AWD to RWD will not handle as well as it did stock unless you change/adjust the suspension accordingly. Corner-balancing is especially important.
Drag radials are ot made for handling. They're made for hooking in a straight line. If you want a tire that does both...r-compunds are the optimal choice.
i did both, i had custom motons and corner balanced (by moton/ ray) but ,its no longer the issue of suspension. for me its driver error. its the boosting, that is too hard to modulate, even with a progressive(boost adjusted per gear) boost rate. it just spools up too quick.
well, you obviously are a much better driver than i cause i dont find it to make any sense for me, its fun but thats it.
Anyway, at least you gave it a shot. Now you know for sure that staying AWD on a Gallardo is what works best for you.
With what kind of tyres was this? Street legal?
Cheers.
