Need help removing k16 turbos
Old Oct 12, 2007 | 11:12 PM
colorinc's Avatar
colorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond repute
We are removing the k16's and have had no problem getting 2 of the oil lines disconnected. The top fat line that goes to the oil tank when we are trying to unscrew the whole line is twisting and we cannot get it disconnected. We are trying a loosening spray, twisting back and forth but don't want to bust the line.
Any suggestions?
Old Oct 13, 2007 | 12:12 AM
Evader's Avatar
Evader is infamous around these parts
I have not done much work on Porsches but, I had a Audi S4 with a similar problem.
First make sure you protect all surrounding areas wiht non-flamible material. Then try applying a mild hand held mapp gass or propane torch to it. You can watch the metal discolor and it should expand slightly. Becarefull as the lines are thin and many adjacent materials are flamible or have flamible fluids.
Having a second hand with an extinguisher is a good idea.
This method is not for noobs and should only be attempted as a last effort!
socialpro
Cayenne 958
May 18, 2016 09:58 AM
DonBond
Apr 16, 2016 07:55 PM
Sep 1, 2015 03:16 PM
Lucid Moment
Aug 20, 2015 02:22 PM
Aug 19, 2015 06:55 PM
