headlight removal help
Old Oct 27, 2007 | 07:26 PM
drewTT's Avatar
drewTT has a spectacular aura aboutdrewTT has a spectacular aura aboutdrewTT has a spectacular aura about
i am trying to replace a burn out parking bulb and i can't get the passanger headlight out. i keep turning the screw inside the fender but it does not do anything...
can anyone help here?
Old Oct 27, 2007 | 07:33 PM
BoxsterGirlie01's Avatar
BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !
i had the same issue when we installed our HID's. try moving it downward and at an angle. also, if the light moves a bit while you're using the tool, try manually moving the headlight with your hands. push it in as far as it will go in, etc. honestly, i think the headlight gets hung up on the plastic side pieces that the headlight slides onto when it gets put in.
anyway, i'm sure i've confused you! lol! but my headlight does this everytime i take it out. i have to manually move it...push it....pull on it..etc.
good luck!
Old Oct 27, 2007 | 10:11 PM
Beecher's Avatar
Beecher is infamous around these parts
Wink
Make sure the tool had really engaged the screw. You only have to turn it 90 degrees and the light should move forward a little bit. Grab the light and ease it out. To install, push the light back in and then turn the screw back 90 degrees to its original position.
NIKAS
Aug 20, 2019 07:53 PM
markj
911
Apr 7, 2016 05:44 PM
Feelgood MD
Mar 24, 2016 09:35 AM
XLR82XS
Oct 5, 2015 07:02 AM
AM v12v
Sep 4, 2015 02:52 AM
