dyno day - who will step up?
Old Dec 10, 2007 | 09:03 AM
  #166
Zuma 911's Avatar
Zuma 911 has a spectacular aura aboutZuma 911 has a spectacular aura about
I too challenge the calibration of the dyno...the numbers are just plain.... low.
Old Dec 10, 2007 | 09:06 AM
  #167
Zuma 911's Avatar
Originally Posted by msidrd
should be able to install all this stuff this Saturday
Be glad theres 24 hours in a Saturday....thats a handful
Old Dec 10, 2007 | 09:09 AM
  #168
NineNineSixTT's Avatar
NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !
I would like to see what Dan from Harman, has to say about this....
Old Dec 10, 2007 | 09:20 AM
  #169
Onetime's Avatar
Onetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant future
Old Dec 10, 2007 | 09:37 AM
  #170
Zuma 911's Avatar
Originally Posted by Onetime
Lucky for me I found 40 Hp in the parking lot, unless Fabspeed is lying to me
Old Dec 10, 2007 | 11:11 AM
  #171
drewTT's Avatar
drewTT has a spectacular aura aboutdrewTT has a spectacular aura aboutdrewTT has a spectacular aura about
i dont think the dyno is off...the stock TT made 338whp which is about a 20% loss....that puts it right at 415
Old Dec 10, 2007 | 11:15 AM
  #172
drewTT's Avatar
plus my 440 translates to 550 crank HP which is exactly how the car feels.
Old Dec 10, 2007 | 11:16 AM
  #173
Zuma 911's Avatar
When you look at it this way, I think Drew is right, the numbers are right on. The harsh truth hurts.
Old Dec 10, 2007 | 11:25 AM
  #174
DLSJ5's Avatar
DLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond repute
It's def off on Karl's car, dont' you think?
Old Dec 10, 2007 | 11:30 AM
  #175
drewTT's Avatar
Originally Posted by DLSJ5
It's def on on Karl's car, dont' you think?
they probably turned the load wayyyy up on karls car. i heard Dan doesn't like stage 3 s4s...HAHAHAHA
just kidding karl
yeah i don't know, his numbers were really low
  #176
Harman Motive's Avatar
Harman Motive is infamous around these parts
I agree that the numbers produced by this dyno are conservative. It is well known through the tuning community that Mustang dynamometers will read on conservative side - I knew this when we purchased the dyno.
My experience with dynos is a little more complete than most. I have now owned two dynos (Dynojet and Mustang), dynoed well over 1,500 cars over the last 4 years, and spent most of those runs performing custom tunes. I have also tuned vehicles on Dynapack, Dyno Dynamics, DTS, Maha, and Bosch dynamometers. So while the information below may simply be my opinion, I've got the time invested to back it up.
Cliff Notes:
1) Mustang Dynamometers generally read on the low side of the spectrum.
2) We had a Mustang technician fly out here to calibrate our dyno on site after we installed it. I check/recalibrate the dyno monthly during our routine maintenance.
3) I owned and operated a Dynojet for 3 years before we installed the Mustang, and trust me, I changed dynos for a reason (it ain't cheap).
4) The Mustang dyno combined with our enclosed dyno-test cell provides the truest simulation of real world conditions. As such, regardless of how "high" the numbers are, they are more comparable/repeatable and as such are more useful than numbers provided by some other dynos and test cell setups.
5) The accuracy of a dyno and its calibration is about consistancy, repeatability, and correct simulation of real world conditions - not how high the numbers are.
6) I am not knocking those who want to see higher numbers. As with all things in life, you need to make compromises. In upgrading from our Dynojet to the Mustang we decided repeatability, consistancy, and tuning quality were more important than higher numbers.
I purchased the Mustang dyno last year when we decided to move into a larger facility. I decided it was time to upgrade from the Dynojet 424X we had in our old shop for the last three years. Furthermore, I decided it was time to invest in a proper test cell to improve repeatability and testing accuracy. This was an extreme investment in money, time, and engineering - but I got into this business to do the best work possible, not just to get by.
It was well known to me that the Mustang would read lower than the Dynojet. I accepted this knowing that the improvements gained from having a proper load-bearing dyno would far outweigh the marketing power of higher numbers.
What I like best about the Mustang is the integrated eddy-current load cell and the software that controls it. The load cell applies resistance (load) to the vehicle as it accelerates. By entering the vehicles weight and aerodynamics (hp @ 50mph), the Mustang calculates the amount of resistance the vehicle would encounter on the road at a given speed. As such, load is increasing as the vehicle speed increases.
An excellent example of the accuracy of this loading was done during the dyno day. We ran a few of the cars in 3rd and 4th gear - the numbers/graphs produced were almost identicle in each gear. The would not be so on the Dynojet or an insufficiently ventilated test room.
The Dynojet we had before was an inertia dyno. The load was simlpy from the weight of the rollers themselves (~2500lbs each). As such, running vehicles in different gears produced different results. Furthermore, the resistance did not increase as speed increased - unless you are driving your car on glass in a vacuum, that just doesn't equal the real world.
The real benefit of all this really shows when tuning vehicles and when analysing the quality of the tune. With the applied load on the Mustang, you are less likely to get away with a tune that is too agressive or poorly matched to the vehicle. This can be seen in power dips, lumpy curves, etc. On a Dynojet or similar, the lower loads at high speeds usually will let you get off a couple of runs before you see any of this behavior (I found that I had to check/retune some of the cars we ran on the Dynojet).
So, while the numbers may be low, the data it is presenting to the reader has more value. The Mustang dyno combined with proper ventilation and calibration allows you to see how your car is running on the road - not just how your car runs on the dyno.
It can be argued that all this is rather unneccesary if you are just trying to get a power number out of a car, but why go through the trouble of printing a graph if you just want a number
If you guys have any other questions just let me know.
Best Regards,
Dan
Old Dec 10, 2007 | 11:35 AM
  #177
DLSJ5's Avatar
Cliff Notes:
Best Regards,
Dan
Good stuff Dan! I dont' think the #'s are off really, but a few cars did lower than expected, but that's how it always goes. I'm happy as I did a little better than I thought I would on the Mustang.
Old Dec 10, 2007 | 11:40 AM
  #178
mspiredm3's Avatar
mspiredm3 is infamous around these partsmspiredm3 is infamous around these parts
440awhp 488awtq
K24s, GIAC race file, tubi exhaust, evo wgs, BMC filter
Nice numbers bro! I really want to see your graph...
Originally Posted by bone_doc s4
hey guys, fun times ... BIG thnx to DrewTT for setting it up.
My numbers were 410whp/428wtq.....those numbers dont quite add up to me--oh well. I guess they dont like Audis
Drew M3, did you shove a potato in Karl's muffler?
Those numbers look way off bro, weird.....
Old Dec 10, 2007 | 11:48 AM
  #179
drewTT's Avatar
thanks mike. i will scan it
Old Dec 10, 2007 | 11:53 AM
  #180
DLSJ5's Avatar
It was the only way I could beat him!!!!! I'm sorry Karl. Dan went along with it though, he really doesn't like S4's, hahahaha.
