Tire Pressure
Old May 23, 2004 | 06:10 AM
ttgangsta's Avatar
ttgangsta has a spectacular aura aboutttgangsta has a spectacular aura aboutttgangsta has a spectacular aura about
Tire Pressure
I need to know that the best tire pressure would be for a set of 19s (315-25 rear and 235-25 front). Sorry if this is a repost, but i could not find the search link.
thanks bill
Old May 23, 2004 | 06:12 AM
KPV's Avatar
KPV
36f, 44r
Old May 23, 2004 | 06:13 AM
ttgangsta's Avatar
^ Even if they are 19s? We have really rough roads in norhteren Ohio.
Old May 23, 2004 | 06:40 AM
KPV's Avatar
KPV
I ran those pressures the other day on the track and the scuffing was perfectly at the edge of the tread, not more, not less. This tells me it was correct.
Old May 23, 2004 | 06:55 AM
carbonissimo's Avatar
carbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud of
Cool
I ran the same pressure at Sebring and found it to be perfect.
On 18's.
Old May 23, 2004 | 07:13 AM
Joe Weinstein's Avatar
The tires are going to need the pressure. The 19" wheels
are unavoidably going to be harsher on bumps because
they effectively remove one inch of cushioning between
you and the road. If/when you want comfort and
performance, run your stock tires and wheels.
Old May 23, 2004 | 08:24 AM
ttgangsta's Avatar
Joe i am running 40 (front) 45 (back) because i was afrid they might dent, i have no problem running with higher pressure. I Know the manule says 36.5 in the front and 41 in the rear so i thought it might need more since there is less tire wall.
Jul 29, 2019 11:13 AM
RallyBird
Oct 7, 2015 01:20 PM
horsepowerfarm
Sep 10, 2015 06:09 PM
The Oss
Aug 24, 2015 08:19 PM
