cant check my oil...level sensor in dash doesnt work...
Old Nov 7, 2007 | 09:36 PM
DMaffo's Avatar
DMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud of
Ive been replacing oil regularly and its getting crazy expensive to be doign this over and over agian.... porsche said replace the sensor and I DID.... still no luck.... you do the measure thing at temp with the car stand still as I would do before and it shows full bars... always.... even when I know for a fact it doenst have enough in it... what gives?? anyone had this happen?? what do I do?? any suggestions???
Old Nov 8, 2007 | 02:23 AM
It happened to a few guys here.... not sure on the solution...
Did u get that speed sensor replaced or will u be asking about that one next LOL
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Nov 8, 2007 | 07:47 AM
DMaffo's Avatar
i already did ask about that...take a look... I posted 3 problems!!!
Old Nov 8, 2007 | 12:50 PM
mmmmm's Avatar
mmmmm is infamous around these parts
Did all your problems occur all at once? Seems like you are running to uncommon problems.
Old Nov 8, 2007 | 01:06 PM
oak's Avatar
oak
check all common grounds. after checking the most simple stuff first. like fuses etc...
Old Nov 8, 2007 | 01:15 PM
DMaffo's Avatar
not at once... I had little problems turn into this now.... my bad... i shoould of done things earlier..!!
Old Nov 8, 2007 | 01:48 PM
otherhwhitemeat's Avatar
otherhwhitemeat is infamous around these parts
Check the wiring, cant hurt, wired pretty simply. pull the cluster, remove blue connector. On the blue connector you can pin out the oil level sensor, (just dont stick anything in to large that will spread apart the pins so they wont read when you reconnect.) On the blue connector pin 2 is signal/ pin 18 is ground. You can check all the wiring right here including sesnor resistance (shoud read 18-25 ohms between the 2 pins) could just be a bad new sensor (if only)and wiring for an open circuit from pin 2 on connector to pin 2 on sesnsor and pin 18 on connector to pin 4 on the sensor (should read <5 ohms) . Check for short to ground from pin 2 or 18 (should read open circuit or OFL). Then again maybe the cluster just took a dump. good luck. hope it helps
Old Nov 8, 2007 | 01:50 PM
DMaffo's Avatar
ill do it at home tonight... thank you....
Old Nov 8, 2007 | 02:20 PM
Chuck Jones's Avatar
Chuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond repute
this is the first car I've ever owned that didn't have a dipstick....I'm having a hard time getting used to no positive means of double checking the oil level. Some of this stuff that falls into the drive-by-wire scenario doesn't sit right with me. I guess that's the future.
Old Nov 8, 2007 | 02:34 PM
Ah-yes technology- but cant say I miss the days of spending an entire damn afternoon synchronizing webers
Old Nov 8, 2007 | 02:36 PM
porschedude996T's Avatar
porschedude996T is just really niceporschedude996T is just really niceporschedude996T is just really niceporschedude996T is just really niceporschedude996T is just really nice
I have had very good luck with liquid level gages on all of my 911. Starting with my '72. After a few years of reading and checking againist the dip stick, I quit checking the dip stick all together. On my '91 964 I did the same. So this doesn't concern me in the least.
Having no indication of what is in the tank does concern me...
Old Nov 9, 2007 | 06:25 PM
jamie furman's Avatar
jamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond repute
You might try to just take it to the dealer and let them fix it?
Old Nov 10, 2007 | 07:53 AM
Smile Trouble-Shooting is FUN
Give up and take it to the Stealer, well that is not the spirit of this forum... If everyone had that same answer to the issues here on the 6speed, it would be a corvette forum.
I frequent this forum to give and take and enjoy troubleshooting. In other forums and news groups, I have successfully trouble shot dozens and dozens of Porsche problems. In the case of the 996TT's, I am still in the familiarization phase (1 year).
So in future Jamie, please hold that thought of sending it to the stealer ($$$$$$) that would be the very last resort that is already in the back of everyone’s mind.
Don’t give up DMaffo, there are a lot of smart 6speeder’s here with all the required data to repair the problem. Just follow thru and make sure that you acknowledge the forums member and follow up with the conclusion.
Old Nov 10, 2007 | 08:11 AM
DMaffo's Avatar
i grinded down a vaccum hose for my boost controller and was trouble shootting that last night... It was loose under Y pipe and had to take it all apart but found it... i duct taped it off in mean time till i get another one... that was enough for last night.. it was a bit cold in underground and I was beat..... lol... long day at work... I will get to the other problem and post my progress......
Thank you all !!
Jul 29, 2019 11:13 AM
RallyBird
Oct 7, 2015 01:20 PM
LiquidElephant
Aug 27, 2015 06:17 PM
gulf gt
Aug 27, 2015 10:27 AM
Aug 19, 2015 06:35 PM
