Removing shift knob
You have to pull up pretty hard. I opened the sunroof and stood up inside the car, then just pulled straight up on the shifter. When it lets go, your hands will come flying up, so don't punch yourself in the face in the process.
![hilarious](https://www.6speedonline.com/forums/images/smilies/smLach2.gif)
I can unclip the base, but the **** doesn't seem to want to lift off the stick. How much force should be needed?
I would love to see a video of what went down. hahaha. I can just see a big guy standing up inside the car, and then the boot lets go, and hits himself in the face. Hope everyone has a good weekend, and thanks for the laugh Adam. I owe you one.
Seriously, open the sunroof and stick your head out...that way you will get more leverage on it and you can pull straight up. You will need to pull very hard, but it will come off if it is the stock shift ****.
The aftermarket shift **** I put on my car had a set screw in it, so if someone already replaced the shifter in your car, it may have a set screw in the front closest to the radio.
I'm replacing the shifter on my car with a 997 unit and am stuck. I've searched the archives but have not found another unfortunate soul with my particular problem.
The new unit is in the car but I cannot get the old shift **** off the old shifter. It has a 2.5mm allen set screw that will not budge. I've twisted every allen wrench I have. Took it to my mechanic and he started destroying tools. Has anyone been faced with this and how did you finally loosen the set screw? I hate to drill it out and risk messing up the threads.
I was able to unscrew mine pretty easily with an allen wrench.
If you went to a mechanic and they still couldn't get it off.. I'm not sure what to say. You're going to have to get a great grip on it and lots of leverage. Not the easiest of things given the small screw and space to work.
You may need a plasma torch.
You are lucky that your set screw was not tightened by a gorilla.
Will penetrating oil help to break down thread lock?
I have no idea what could be used. I've broken bolts before that were in with thread lock as the heads broke off before the bolt would break free.
Maybe someone else on here can chime in as to if there's something out there to help break it down. Sorry I don't know more about this..
![Confused](https://www.6speedonline.com/forums/images/smilies/confused.gif)
