Ported Headers
Old Nov 12, 2007 | 11:34 AM
Shark01's Avatar
Shark01 is just really niceShark01 is just really niceShark01 is just really niceShark01 is just really nice
Originally Posted by Christian
^No problem at all, just wondering if it is worth installing, they are pretty simple to do
Someone posted a dyno some time back that showed a 5 hp gain. Not bad if you are taking the turbos off anyway and running the grinder yourself. I bought an extra set for $100, and I'll port them if I ever get the time.
Old Nov 12, 2007 | 12:48 PM
Christian's Avatar
Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !
Looks like I should pass.
Christian
Old Nov 12, 2007 | 02:29 PM
TunaRollZ's Avatar
TunaRollZ is a glorious beacon of lightTunaRollZ is a glorious beacon of lightTunaRollZ is a glorious beacon of lightTunaRollZ is a glorious beacon of lightTunaRollZ is a glorious beacon of lightTunaRollZ is a glorious beacon of light
Originally Posted by wross996TT
The more you restrict the exhaust, to some extent, the faster the turbos will spool (pressure builds faster)...of course the more you restrict the exhaust the less power at the top end you will have. For more power most folks opt for less restrictive air flow all around (more air in and more air out).
sorry, but i have to disagree... restricting a turbo from getting exhaust energy (turbo manifold side) or expelling exhaust gasses (exhaust system side) never helps spool. Turbos hate exhaust pressure.
I'm not saying that properly porting out a stock turbo manifold will be noticeably beneficial. I'm just saying that the concept of restricting a turbo engine's exhaust to gain spool is unheard of.
Old Nov 12, 2007 | 02:43 PM
wross996TT's Avatar
No argument on the ultimate desire to improve air flow through the system and that you would not specifically work to increase back pressure by restricting the exhaust, but the fact of the matter is the spool time for turbos is directly related to the time it takes to build enough pressure to turn the turbos. There are a number of ways to help "build" the pressure. Smaller turbos have a smaller volume of space and therefore spool quicker. Often the reduction of lag will result in less power at the top. Hybrids try to strike a happy medium. For example Zero clearance turbos decrease the space between the blade and the housing thus reducing the amount of lost pressure...therefore pressure builds faster and less lag.
Old Nov 12, 2007 | 03:33 PM
TunaRollZ's Avatar
Creating the right amount of exhaust energy to spool any given turbo can be useful in perfecting your turbo's spool characteristics. I believe that building a "perfect" exhaust manifold for that particular turbo is key (I'm intentionally ignoring the post-turbine exhaust side as I think we both would agree that the best performance exhaust system for any turbo is having no exhaust system at all).
In other words, if it's an OEM turbo manifold, it may have some kinks and jagged edges that impede exhaust flow (in some cases the piping is too small to allow optimum flow - probably not in the 996TT's case for k16 turbos). In such cases, cleaning up a turbo manifold like this may see some gains/spool improvements - depending on how bad the design was to begin with. There's probably not a whole lot to gain from working on the 996TT manifold when dealing with stock k16s. But I believe that if you port it out to the point that you're experiencing a negative performance impact, it's not because it wants X psi of pressure, but because it's taking far too long for the gasses to get down into the turbine. Any poorly designed manifold could fall victim to this, but I see where you make your point that this is where more "pressure" would be beneficial. I just don't like calling it pressure I guess... I look at it as optimized exhaust flow. I think we're in agreement though. ya?
Old Nov 12, 2007 | 03:42 PM
WOODTSTER's Avatar
You could buy the ****ty chinese made headers like I have and just hope you have
made some mad power...
MK
Old Nov 12, 2007 | 03:44 PM
wross996TT's Avatar
Yes Tuna, Absolute agreement...well said.
Old Nov 12, 2007 | 11:35 PM
oak's Avatar
oak
I doubt even 5hp. that would be generous.
Rguy
Apr 12, 2020 11:11 PM
gadgetman
Sep 21, 2015 06:55 AM
arhim22
Sep 7, 2015 08:49 PM
Sep 3, 2015 04:56 PM
shifter_
Sep 2, 2015 03:33 PM
