Ported Headers
Old Nov 11, 2007 | 06:33 PM
Christian's Avatar
Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !
Ported Headers
Any advantage of ported headers if the car is less than 600 rwhp?
Christian
Old Nov 11, 2007 | 06:39 PM
tom kerr's Avatar
I think most guys will port and polish their stock headers for max exhaust air flow if you are below 600hp and it certainly doesnt hurt. The question is usually do you need non-factory headers, there the answer at that hp level is probably no.
Old Nov 11, 2007 | 08:05 PM
oak's Avatar
oak
they are so restrictive you leave so much on the table if you don't port them.
Old Nov 11, 2007 | 10:29 PM
Chuck Jones's Avatar
Chuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond repute
Oak states...."they are so restrictive you leave so much on the table if you don't port them."
Oak: What are you basing that statement on? Do you have some dyno or other test results that substantiate that statement? I'm not being argumentive with you....I'm just truly interested in what sort of flow restrictions a set of stock headers might have....and if so, I would be interested in trying to correct that....however I do not intend to chase 600 HP, so other comments about porting not being worthwhile for lower HP would be a valid reason for not spending the money to port them.
Old Nov 11, 2007 | 10:49 PM
oak's Avatar
oak
chuck, you must be relatively new to the board. I was being facetious. grinding .050" of weld "crown" will not net any noticeable or measureable gain. total waste of time.
Old Nov 12, 2007 | 06:13 AM
hydeaway's Avatar
hydeaway is infamous around these parts
what he said, "total waste of time"
Old Nov 12, 2007 | 07:45 AM
S4corrado996TT's Avatar
S4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really nice
Oak! Who would you suggest to perform the best port and polish work for factory header? TKS!
Old Nov 12, 2007 | 07:51 AM
wross996TT's Avatar
come on Oak...MAD POWER!
Old Nov 12, 2007 | 08:26 AM
996Choy's Avatar
996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of
So when (what power level) should you start doing it
Old Nov 12, 2007 | 08:51 AM
oak's Avatar
oak
oh yeah, MAD POWER!!!!
Old Nov 12, 2007 | 08:53 AM
Christian's Avatar
Not worried about more power, but does it help the 16/24's spool quicker
Old Nov 12, 2007 | 08:55 AM
oak's Avatar
oak
spool quicker? no.
Old Nov 12, 2007 | 09:01 AM
wross996TT's Avatar
The more you restrict the exhaust, to some extent, the faster the turbos will spool (pressure builds faster)...of course the more you restrict the exhaust the less power at the top end you will have. For more power most folks opt for less restrictive air flow all around (more air in and more air out).
What is the problem you are having with your hybrids spooling? Mine spool quite quickly...
Old Nov 12, 2007 | 09:03 AM
Christian's Avatar
^No problem at all, just wondering if it is worth installing, they are pretty simple to do
Old Nov 12, 2007 | 10:46 AM
Oak: I am new to the board....I know some of the guys on the other forums and know when the B.S. factor is flying, but haven't figured that out for this board yet. Thanx for the heads up.
