Transform your GT700 now!
Old Nov 18, 2007 | 10:45 AM
ldc's Avatar
ldc
ldc is a jewel in the roughldc is a jewel in the roughldc is a jewel in the rough
How fast does the data refresh on that Brockway device, is it slow like the stock boost gauge?
dc
Old Nov 18, 2007 | 10:57 AM
Adam Bowles's Avatar
Adam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud of
So the Brockway unit has an OBD connector on one end and just plugs into your cars OBD connector? Do you have the single DIN mounting plate in your car?
Old Nov 18, 2007 | 11:31 AM
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
I do not use the brockway as a boost gauge - I have the Greddy which responds quickly, quicker than the stock gauge. I am not sure how the Brockway performs if connected to boost, but the AFR updates instantly.
Adam, that is the DIN plate, but I trimmed it a bit to configure to the shape of storage bin, which is not square. It would fit in the next spot up, where I have my Greddy without trimming it. Since I am making a custom CF plate for the Brockway, it didn't matter to me, as I will have to do more trimming before it's ready to send out.
Yes, it just plugs into the OBD2 port - that's it. Connection could't be easier.
Old Nov 18, 2007 | 11:45 AM
buddyg's Avatar
Originally Posted by bone_doc s4
BuddyG, nice work!! So you couldnt change your boost settings before? What was your max boost before Greddy BC?
And you're right, why doesnt that kit come with EBC from EVOM? Are you running GT28s? Besides rod and studs, what other internal mods did you do?
thnx
The GT700 comes with pump gas and race gas programs. On race gas I was at 1.3 bar max. Yes running GT28's.
This is my motor build:
Complete disassembly of engine down to the crank
-Inspect, size, spec out all parts including: crankshaft, pistons, valves, guides, cams, springs, etc.
-Inspect for unusual wear, measure all wear components to determine if they are within specifications and address any problems
-Sonic clean components and prep for reinstallation
-Inspect valve train and reseat valves with hand lapping method
-Install new GT3R racing high flow oil pump
-Install new crankshaft, intermediate, rod and main bearings Install new Carrillo Connecting Rods w/ multi torque rod bolts (carr bolts)
-Install new high strength aircraft quality head studs / hardware
-Install EVO designed high pressure head gaskets
-Install and gap new piston rings
-Install new OEM o-rings, seals and associated gaskets
-Build bottom utilizing OEM & EVO developed high power building procedures
-Time camshafts utilizing OEM timing tools
-Install all associated induction / top end components with all new gaskets and seals
-Secure and zip tie all vacuum / pressure lines as required for high power applications
Old Nov 18, 2007 | 03:04 PM
Zippy's Avatar
Buddy - this sounds really interesting. When I get around to having my internals done, I will definately do this. Are you running the normal GT700 file or are changes required to compensate for the 5 bar FPR.
Thanks, Mike
Old Nov 19, 2007 | 03:55 PM
medici78's Avatar
medici78 has much to be proud ofmedici78 has much to be proud ofmedici78 has much to be proud ofmedici78 has much to be proud ofmedici78 has much to be proud ofmedici78 has much to be proud ofmedici78 has much to be proud ofmedici78 has much to be proud of
Will a boost controller work on 'lesser' power packages?
Old Nov 19, 2007 | 03:57 PM
buddyg's Avatar
Thanks, Mike
Mike,
I am just running the GT700 race program for Hitachi Maf.
Old Nov 19, 2007 | 03:58 PM
buddyg's Avatar
Not sure but I don't see why not?
Old Nov 19, 2007 | 05:00 PM
Saint Ari's Avatar
Saint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud of
Originally Posted by buddyg
I don't have third gear!
I am most likely mistaken, but I was under the impression that for 996TT's ... we do 4th Gear pulls for Dynos .....
Old Nov 19, 2007 | 06:27 PM
oak's Avatar
oak
why not just do the GT800 kit?
Old Nov 19, 2007 | 06:33 PM
Zippy's Avatar
...spool.
Have you tried running your new setup on the 91 file too?
Also... Have the boys at EVO given this the "2 thumbs up"?
Thanks Buddy.
Mike
Old Nov 19, 2007 | 07:48 PM
Al Norton's Avatar
Al Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud of
Buddy,
When doing your EBC research, did you consider the HKS EVC VI? If you ruled it out, please tell me why. It is the one I am presently considering.
Nice to chat with you in Atlanta the other evening.
Old Nov 19, 2007 | 08:16 PM
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
...spool.
Thanks Buddy.
Mike
The new gt800 with 3.8l kit has full boost 300rpms later than the gt700, not too bad at all!
Jag
Old Nov 19, 2007 | 08:18 PM
Highhats's Avatar
Highhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to behold
look what I started lol
EBC's for everybody!!!!!!
Old Nov 19, 2007 | 08:26 PM
buddyg's Avatar
Yeah I think you are right!
