My Maf Is Going Bad
Old Nov 19, 2007 | 03:31 AM
Afg's Avatar
Afg
Afg is infamous around these parts
My Maf Is Going Bad
i checked with the bosch Computer and the maf is little tired so i reset the code for now .. am going to buy other Maf So what did u say guys ? Bosch Maf or hitachi maf? what is the better ?
Old Nov 19, 2007 | 03:34 AM
FL TT's Avatar
FL TT is infamous around these parts
mustang is an option to consider. it is rumored to be a reliable solution (protomotive).
Old Nov 19, 2007 | 03:44 AM
Afg's Avatar
Afg
What did you Prefer guys? bosch or Hitachi
Old Nov 19, 2007 | 07:48 AM
wross996TT's Avatar
What do you mean by better? It depends on your tune/tuner. Is your ECU set-up for anything other than the Bosch Maf? If not stick with the stock one...
What do you mean you checked with the bosch computer? What do you mean the Maf is tired? The Maf may become dirty with oils and particles for which cleaning with an electronic cleaner may be appropriate, but after that it either works or is fried and can not be brought back to life.
Old Nov 19, 2007 | 10:28 AM
Afg's Avatar
Afg
Before every thing my tune right now is factory tune .. i checked the car with a Bosch Computer in my friend garage .. its comes like sign on the pc .. Maf Sensor ,, and we reset the code .. btw the rpm is little playing like 900-850 .. he toled me that from the maf sensor change it and every thing will be well
so im Worried dunno what to do to solve this problem
Old Nov 19, 2007 | 11:29 AM
NelsonF's Avatar
NelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to behold
Maf
Just swapped out my stock maf for the Hitachi unit with associated revised ecu programming. Seems to be pulling a bit harder than previous and I've seen 1.5bar spikes on the stock guage vs. 1.4bar spikes previously. However, when combined with a lwfw as on my GT2, I am still seeing the occasional stall upon slowing to 1st from speed. EVOMS, is in process of addressing this issue with a modified program for those with the lightweight flywheel. Will advise on my impressions once I get the update.
Old Nov 19, 2007 | 12:58 PM
Afg's Avatar
Afg
thanx 4 the information .. but my problem little making me confuised .. my Ecu is stock Ecu so what do i used Oem or Bosch ? i need something with out any tune or something like this !!
Old Nov 19, 2007 | 01:06 PM
NelsonF's Avatar
Maf
If your car is stock with Bosch Maf, you'll have to stay with the same one. The Hitachi Maf is optimized for higher power cars and requires reprogramming the ecu. Not sure about other Mafs.
Old Nov 19, 2007 | 01:14 PM
Afg's Avatar
Afg
Thanks NelsonF ,, But as i think mines are the one's comes from the factory they come by bosch or what am searching for a good maf because my rpm is playing little 900-850 something like this do u think its from the maf right? i checked the car on computer some sign come in the computer from the maf and i reset the code so i don't know what to say but am not that happy lol
Old Nov 19, 2007 | 01:23 PM
NelsonF's Avatar
Maf
If your car is stock and still under warrantee, I'd have your dealer check it out and possibly replace(under warrantee). If not, you might try some electronic component spray cleaner and see if it helps before attempting replacement. It's not difficult to do.
Old Nov 19, 2007 | 01:32 PM
Red996's Avatar
Red996 is infamous around these parts
my opinon change ur maf
Old Nov 19, 2007 | 01:48 PM
NelsonF's Avatar
Maf
A dirty Maf could easily be causing your rpm fluctuations. I would try that first. If your air filter is not stock and/or is dirty, it might also be a culprit. Good luck. By the way, if the car is just recently off warrantee, you might have the dealer check as he may replace as a good will gesture since it's not a major proceedure. Worth a try.
Old Nov 19, 2007 | 02:07 PM
oak's Avatar
oak
Scrub Your Maf.
Old Nov 19, 2007 | 02:27 PM
Afg's Avatar
Afg
the warrantee finshed from 1 month ago lol 2moro i'll check what to do .. i know its not a diffcult only opening it and cleaning it ehehe thanx 4 helping me .. but b4 i open it u know what i want i want to know the rpm is playing from what
Old Nov 19, 2007 | 02:28 PM
Afg's Avatar
Afg
i'll clean the maf .. and i'll see if the car going good ,, btw i'll check if there a boost leak or something like this if it still from the maf i will replace it Thanks Alot Guys
