Problem with seat memory
Old Aug 20, 2003 | 10:56 PM
racer63's Avatar
racer63 is infamous around these parts
I've found that it always helps to tell the dealer not only what's wrong, but how to fix a problem... Otherwise, it seems like the odss that they can fix it are about 50-50... With that in mind, I'm about to take the 996TT into the dealer for the following problem.
When you unlock the doors and open the passenger's side door, then the driver's side lumbar support will inflate to a unusually high level (higher than my memory setting). If you open the driver's side door, and don't open the passenger's side door, it won't inflate (i.e., it stays at the saved setting).
Has anyone had this happen, and do you know of a solution?
Thanks in advance.
007AMV8
Oct 19, 2015 09:55 PM
Michael_s
Sep 11, 2015 08:03 PM
LiquidElephant
Aug 27, 2015 06:17 PM
pwdrhound
Aug 23, 2015 07:36 PM
pwdrhound
Aug 20, 2015 05:54 AM
