static vs. Rolling dynos
Old Aug 21, 2003 | 06:24 AM
MWILENS's Avatar
Awaiting Email Confirmation
MWILENS is infamous around these parts
I was reviewing Stephen’s numbers and can say that I am truly grateful to have a guy with his knowledge, passion and sincerity on this board. However I couldn’t help but wonder if the results would be different if a static dyno was used. I have heard from several reliable sources that Alois Ruf has tested all the exhausts on static dynos rather then rolling dynos b/c of the slippage factor and trying to maintain parity between runs. I also think that in most cases people should listen to the exhaust rather then just going for the max hp. I have had many exhausts on my car and find the sound quality to be the most important factor to me.
Old Aug 21, 2003 | 06:56 AM
Duane's Avatar
Duane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud of
Obviously there are many factors. Stephen took several different exhausts on the same car in very simialar situtaions. Some performed much better than others. One would have to think if the same tests were performed on a static dyno that the numbers might vary, but the end result would be the same as Stephen's numbers!!!
Duane's Avatar
Oh Ya and I am greatful to have have Stephen's wonderful mind on the board as well!!!!!!!!!!!!
Rguy
Apr 12, 2020 11:11 PM
TitanMotorsport
Nissan GTR
Sep 23, 2015 03:25 PM
Texas1
Sep 20, 2015 09:12 AM
AdamNoone
Sep 3, 2015 04:15 PM
