boost lag
Old Nov 30, 2007 | 10:13 AM
smistry007's Avatar
smistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond repute
boost lag
Just upgraded to K24's with evo waste gates. As expected, a little more lag than my K16's but much more top end. When I stomp on it, I see 0.2 bar going to 1.1 bar. I have yet to re- flash my ecu for the K24s'.
I used a pressure guage to set the wastegates to start opening at 12 psi.
My question is: At what rpm should I be seeing a particular boost number? Seems like I am only building boost above 3k rpm. I thought with the upgraded wastegates I would see a little more boost earlier.
Sameer
Old Nov 30, 2007 | 11:13 AM
kilrgt's Avatar
kilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to behold
I think once you do a proper flash, you will see the K24 work the way they should. Just a thought
Old Nov 30, 2007 | 11:59 AM
Pierre996TT's Avatar
Pierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura about
You have to flash it.
https://www.6speedonline.com/forums/...d.php?t=104305
I did start a thread while ago about:
From OEM IC -> EVO IC's with K24 more Turbo lag?
with the OEM (no-X50) ICs, K24's, GIAC Stage 4, EVO WG, up-graded Headers, CarGraphic, Gemballa deck lip (feeds more air).
https://www.6speedonline.com/forums/s...ad.php?t=84710
and I must say in 2 different test, same place, 4th gear run 35 mph to 135.
- Under 2,000 RPMS no boost with OEM, 0.1 -0.2 bar with EVO.
- 2,500 0.3 bar OEM, 0.4 bar with EVO.
- 2,800 0.5 bar OEM, 0.6 bar with EVO.
- 3,200 0.9 bar OEM, 0.9 bar with EVO.
- 3,600 1.2 bar OEM, 1.3 bar with EVO.
- 4,200 1.3 bar OEM, 1.3 bar with EVO.
- 4,600 1,2 bar OEM, 1.3 bar with EVO.
- 4,750 1,2 bar to RED line both.
Test was at OEM IC's 56°F and EVO IC's 70°F
Here is a video with OEM IC's:
http://www.youtube.com/watch?v=XvQYrBrdn4A
I hope it helps....
Old Nov 30, 2007 | 12:01 PM
iLLM3's Avatar
You need a flash ASAP, it will be a dramatic difference!
drewTT's Avatar
drewTT has a spectacular aura aboutdrewTT has a spectacular aura aboutdrewTT has a spectacular aura about
get the correct flash right away. you are in danger of overboosting the k24s with the k16 flash! definitelly no stomping till you get the correct flash...
Sameer
Old Nov 30, 2007 | 02:44 PM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
3200 rpm is when the K24's start to spool.
Old Nov 30, 2007 | 04:56 PM
Dont run the car without the flash... you may run lean and KABOOM....
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Emre@Esmotor
Oct 19, 2015 12:06 PM
whtrabt
Oct 5, 2015 05:23 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
panas001
Sep 27, 2015 02:51 PM
