Lwfw....get One!!!!
Old Dec 8, 2007 | 10:29 AM
Adam Bowles's Avatar
Adam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud of
Would you say the car is still very driveable? How does it compare to the OEM flywheel in traffic and around town?
Old Dec 8, 2007 | 10:34 AM
Evader's Avatar
Evader is infamous around these parts
Are you experiencing the typical tell tale LWFW chatter at idle?
Old Dec 8, 2007 | 02:07 PM
oak's Avatar
oak
anyone else experiencing the engine to die out off idle with the lwfw?
Old Dec 8, 2007 | 03:26 PM
carendt242's Avatar
carendt242 is a jewel in the roughcarendt242 is a jewel in the roughcarendt242 is a jewel in the roughcarendt242 is a jewel in the rough
what are your mods and set-up?
the ECU needs to be adjusted to account for the LWFW; otherwise, you may die off idle as you're experiencing.
i was having great trouble w/ the Hitachi MAF for the gt700 - it died every stop sign/light. from my limited understanding, they took a poke inside the RS and discovered it added some gas at the bottom. they made the adjustment and car runs excellent again.
- chuck
Old Dec 8, 2007 | 03:31 PM
dixie's Avatar
dixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to all
My ECU is not adjusted to account for the LWFW and it never dies off at idle.
A little rattle,but handles as easy as OEM set up..
Old Dec 8, 2007 | 04:46 PM
Onetime's Avatar
Onetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant future
I heard Drew's car today and the rattle is minimal. It's very hard to hear. I've heard others that sounded terrible.
Old Dec 8, 2007 | 05:01 PM
oak's Avatar
oak
what type of pp and fw set up does drew run?
Old Dec 8, 2007 | 06:02 PM
drewTT's Avatar
drewTT has a spectacular aura aboutdrewTT has a spectacular aura aboutdrewTT has a spectacular aura about
it only stalled once on me and that was after i blipped it at idle the first day i got it. no issues since then.
Old Dec 8, 2007 | 06:26 PM
9Eleven's Avatar
9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute
Drew, you've got to give us an entire report on this modification. There are many members contemplating this move. Does it have a steady idle? I was told that the LWFW will cause the ECU to have trouble stablizing the idle because of the reduced weight. How loud is the chatter, really? Is it harder to get it out of the hole? Come on dude, give us a total report.
Old Dec 8, 2007 | 06:46 PM
drewTT's Avatar
its very streetable. the clutch feels exactly like the stock one. the flywheel does chatter but it does not bother me at all. with the windows down you barely notice it. windows up you can hear it at idle. its not bad at all though for me anyways, others can be more sensitive. i would suggest you find someone with it and get a ride in their car or drive it. i have not had any ECU issues with idle or anything. it only stalled once.
Old Dec 8, 2007 | 06:48 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
is it truce that your computer learns??? mine died twice on coasting to a stop.... the rattle is no big ,love the clutch feel
Old Dec 8, 2007 | 06:53 PM
drewTT's Avatar
mine has never died coasting to a stop yet. it only died when i blipped the throttle at idle one time.
my mechanic did say it takes the car a little time to adapt to the lighter flywheel.
Old Dec 8, 2007 | 07:18 PM
Billystang's Avatar
Billystang is infamous around these parts
i talled a customer today about installing a LWFW in my car and he asked me something about if i have to rebalance the engine when i install the Lwfw.
What you guys think about that.
Old Dec 8, 2007 | 07:34 PM
AG996LV's Avatar
AG996LV is infamous around these parts
I have Kevin's setup as well. The clutch feels like stock, but revs faster. The chatter is there if you listen for it, but it's really no big deal. It doesn't bother me because I know what it is, and you really can't even hear it with the stereo on.
If you have the stereo off and are in neutral with the clutch out it has a little mechanical growl to it. It is more noticable with the A/C on, I don't know why.
Everyone knows the noise goes away with the clutch pushed in, but it also goes away without the clutch in just by putting a little pressure on the shifter as if you were going to put it into gear.
The noise is there, but not as bad as some have made it seem, and I still haven't even done the exhaust yet. Those with aftermarket exhaust would probably hear it even less.
Old Dec 8, 2007 | 07:45 PM
USCTrojanMan29's Avatar
USCTrojanMan29 is infamous around these parts
I barely heard the chatter when I heard Drew's car idle today. I'm sure it does help to have a louder exhaust (which I have). This mod is definately on my list along with the LSD.
