RollBar/cage tubing question.
Old Dec 14, 2007 | 02:45 PM
racerjsz's Avatar
racerjsz is a splendid one to beholdracerjsz is a splendid one to beholdracerjsz is a splendid one to beholdracerjsz is a splendid one to beholdracerjsz is a splendid one to beholdracerjsz is a splendid one to beholdracerjsz is a splendid one to beholdracerjsz is a splendid one to behold
Looking at buying a turbo in the future and think a cage/rollover protection may be important. Just in the planning stages. I'd like to incorporate it into the pillars as much as possible. My question is tubing diameter, what is the smallest diameter and thickness that is reasonable.
Most cages are 1.75 or 2.0" OD x .120 (3mm) thick. Would a 1.250 OD tube with a .238 (6mm) wall thickness be as, or stronger?
Has anyone done a Ruf-type cage where it is almost invisable?
Love to see pics!
Thanks!
Old Dec 15, 2007 | 08:13 PM
Fabryce@GMGRacing's Avatar
Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !
This all boils down to who is doing your cage and what materials are used.
I would seek out a experianced cage builder to do your car.
I am not a fan of the 1.75 or 2.0 tubing
We generally run 1.50 chromoly tubing with the proper wall thickness.
Chromoly is not easy to work with and requires a lot of work to fit.
If you are having your car tig welded make sure the welder is experianced and knows how to strengthen the welds.
Many builders use mild steel (DOM) and mig weld.
If you were closer we could do it for you
Old Dec 16, 2007 | 06:44 AM
DERBOOST's Avatar
DERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of light
100% correct, I use 1.50 chromoly .095wall, (.125 wall in some places) light and super strong. Correct tig welding is a must.
Old Dec 16, 2007 | 07:10 AM
Mikelly's Avatar
If you do go the DOM steel tubing, I'd recommend talking with someone about the weight of the vehicle. 1.5 inch mild steel (I know the others are talking cromoly) probably would require something thicker than .125 walls. I know on my Datsun Zcar's cage, we did 1.5 with .125 wall thickness, but the car weighs in at about 2300#. I'm guessing you'd be stuck with something in the 1 5/8th to 1 3/4 range for a TT. I'd refer to a racing clubs rules/ class requirement for guidelines.
Talk to Mitch at Piper Motorsports in Sterling Va. He did the cage in my Zcar, and it's a work of art.
Mike
Old Dec 16, 2007 | 12:00 PM
racerjsz's Avatar
When I'm ready I plan on calling Piper, I say a silver turbo they did that was fantastic.
Glasgo
Nov 30, 2015 02:37 PM
ECS Tuning - BMW
BMW Vendor Classifieds
Oct 1, 2015 03:30 PM
PelicanParts.com
911
Sep 28, 2015 04:26 PM
