Boost problem with Stage 1 ECU
Old Jan 3, 2008 | 07:44 AM
WHAT's Avatar
WHAT is infamous around these parts
Exclamation Boost problem with Stage 1 ECU
A friend of mine just bought a 996TT with an ECU flash and after driving it around for a week, it has developed a problem. It still pushes 1 bar of boost down low, but in the midrange boost drops to .5-.6 bar before building back up to 1 bar near redline.
Any ideas as to what's wrong?
Thanks.
Old Jan 3, 2008 | 08:59 AM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
It could be a sticky waste gate or diverter valve .
Old Jan 3, 2008 | 11:34 AM
nerdhotrod's Avatar
nerdhotrod is infamous around these partsnerdhotrod is infamous around these parts
Thanks.
If he's in CT, I can help him out. PM me.
Old Jan 3, 2008 | 01:15 PM
iJeremy's Avatar
iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !
Did he upgrade diverter's at the time of the Flash?
Old Jan 3, 2008 | 08:14 PM
wross996TT's Avatar
when were the plugs last changed?
Old Jan 3, 2008 | 08:59 PM
derek k's Avatar
derek k is infamous around these parts
You dont mention what type of driveability problem this boost loss is creating. Does it fall on its face?? Does it break up and start to miss??
Both questions asked above are very relevant, dirverter valves replaced?? Plugs replaced?? Either of these can play a part in this issue, if its breaking up my experience says plugs. If its falling on its face it could be the dv's, id replace those either way if they are still factory parts.
Old Jan 4, 2008 | 06:36 AM
kilrgt's Avatar
kilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to behold
Change the DV's first, its pretty simple and an easy DIY, if that fails then change the plugs, they need to be done anyways.Its possible to DIY, but if its your first time you should set aside at least 4 hours........at least
Old Jan 4, 2008 | 07:07 AM
Tym Switzer's Avatar
Tym Switzer is infamous around these parts
It is possible that you've run into a fuel quality issue. Before throwing any parts at the vehicle, it wouldn't be a bad idea to run the tank low and fill up with known good Premium fuel. If the DME is picking up knock, it may be making numerous adjustments around peak torque to calm things down.
Jul 29, 2019 11:13 AM
COBB Tuning
Mar 29, 2016 09:26 PM
nlakind
Nov 6, 2015 10:15 AM
albert@velosdesignwerks
BMW //M
Aug 22, 2015 07:17 PM
