CPO Warranty Worth It?
Old Jan 10, 2008 | 02:54 PM
arr0gant's Avatar
arr0gant is infamous around these parts
Originally Posted by Vyper340
I don't feel that it's worth it as I never used mine and it does not cover what you think it will (depending on the dealer). IMHO you are better off saving the money and using IF something breaks but these cars are tanks and very little if anything is subject to breaking for those model years and what can break will not be covered by the CPO.
Don't waste your money. Apply that to mods and improvements and you will be better off. I wish I didn't waste the money...
You're wrong. The dealer has no say about what is and what's not covered. Dealer covers whatever the CPO warranty covers. No exceptions. You also get complimentary loaners when your car is worked on. Believe me, a CPO is worth it's weight in gold!
Old Jan 10, 2008 | 02:55 PM
OCTurbo's Avatar
OCTurbo is infamous around these parts
The problem with the cpo is that it's only 2 extra years. If you plan on keeping the car for a while, i would go for an aftermarket warranty. I got a 6yr/75k warranty from easy care for about $2700 + another $400 for the pre warranty inspection/oil change.
jb
2003 996tt stage 1
2004 x5
Old Jan 10, 2008 | 03:12 PM
SuperVixen's Avatar
SuperVixen is infamous around these parts
I agree with CPO. If anything goes wrong, you're covered. Plus it helps you later with resale if the car is still under warranty.
Old Jan 10, 2008 | 06:10 PM
Alpha's Avatar
Alpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud of
Originally Posted by Chuck Jones
I was charged for the work required to fix a leak in the F hose that was causing an overboost condition. The factory spring-type hose clamp didn't seal the aftermarket DV properly...even though the clamp was a Porsche factory clamp....but the DV was aftermarket. They installed a screw type hose clamp and charged me $140 for the work. I'm not going to grouse about it becasue the other work covered by the CPO was expensive. So is a CPO worth it? The mental security for some is....others consider it unnecessary.
Chuck -- Did fixing the F-hose leak bring your boost back up to where you had it with the stock DV's?
Old Jan 10, 2008 | 06:17 PM
Chuck Jones's Avatar
Chuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond repute
Alpha: Yes...the boost came back with a vengance...I'm hitting a solid 1.0 and peak at 1.1....the dealership remarked that he didn't know how I was getting so much boost from a stock vehicle...I told him that I didn't have that performance till I put in the Europipe. I'm not versed enough to be able to say conclusively that the EP was responsible or if I just have a boost gauge that's reading high numbers. But the bottom line is that the leak had a definite affect on my boost level, and now I'm back in business.
On the issue of the CPO...today I saved over $1000 with parts they replaced in addition to Porsche paying for the flatbedding of my car 40 miles from my house to the dealership...and the dealership sent a van out to pick me up and take me to my car. But, as I said in another post, the CPO warranty doesn't cover nearly as much as I thought it would...there are a LOT of exclusionary items. The dealer wouldn't give me a list of what was or wasn't covered. I was told that I would be informed at the time they diagnosed the problem if it was covered or not and that Porsche does not release that information. Curious huh? CPO coverage that you pay for but don't know exactly what's covered? Doesn't sound correct to me....
Old Jan 10, 2008 | 06:26 PM
TT Tommy's Avatar
TT Tommy is infamous around these parts
the 996tt is a bulletproof car . The key is to buy the right car that has been checked out by the right PPI shop. CPO's and aftermarket warrantys are a false sense of security a lot of times. They're in business to take your money, not to pay out for repairs.
tw
Old Jan 10, 2008 | 06:50 PM
ard's Avatar
ard
The problem is that language of the CPO is descriptive and no proscriptive. What this means is that it describes the coverage in terms of mechanical failure of various general assemblies, but then has caveats and exclusions. So that for a 'part' to be 'covered' will depend on how if failed (or more accurately how Porsche and the dealer believe it failed).
They are required by law to provide the language- they are not required to give you a 'part number list of covered items'. What will happen is they will cover some parts automatically, reject some, and then ask for further info on others.
I've heard of a dealer refusing any engine related failure if you modified the exhaust, for example. I suspect PCNA didn't know there is a Europipe on that car Chuck.
A
Old Jan 10, 2008 | 07:35 PM
ARD: Thanx for the heads up...going into lurk mode on this subject and be thankful for what I was able to get done.
Based upon your comments, I think your generic signature block might be the way to go.
jaehoppa
Oct 22, 2015 09:17 PM
ModBargains
Oct 13, 2015 03:40 PM
bzimpfer
Sep 26, 2015 10:55 PM
cm09578
Sep 22, 2015 06:07 AM
