Intermittent Boost Problem - quick question
Old Jan 9, 2008 | 08:59 PM
sttjmk's Avatar
sttjmk is infamous around these parts
Recently, when pushing hard in 6th gear, I have noticed that boost will hit 1.1bar, then noticably cut back to 1.0 for a moment, and then return to 1.1bar. It happens infrequently, and only seems to happen in 6th at full boost. It seems to have hit me in the cold weather. Any ideas on what might cause this?
Thanks in advance.
Old Jan 10, 2008 | 07:44 AM
wross996TT's Avatar
Early signs of plugs needing replacement?
Old Jan 10, 2008 | 07:58 PM
sttjmk's Avatar
I am at about 10,000 miles, but have had new software for 5-6000 of those miles. Does that sound like the right time for a chipped x50?
Old Jan 10, 2008 | 08:24 PM
wross996TT's Avatar
Make sure you have the right plugs in there (Bosch FR6LD).
Old Jan 10, 2008 | 09:48 PM
Turbo Fanatic's Avatar
K24 cars NEED upgraded wastegates or wastegate springs to maintain full boost of 1.2 BAR.
It sounds to me like leaky diverter valves or just stock wastegates. The exhaust pressure is forcing your wastegates open prematurely and the ECU can not control that because it's a physical limitation.
Not only will the car run more consistent with wastegates, you will gain a lot of midrange torque and top end power with much crisper pedal feel.
Old Jan 10, 2008 | 09:57 PM
Thanks in advance.
Stock Wg springs do not hold ....
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jan 12, 2008 | 07:43 AM
sttjmk's Avatar
Got it. Thanks. I have seen you guys mention this before, just wasn't sure if my particular symptoms were consistent with stock-wastegate-itis. Will check the plugs anyway when i take it in.
Jul 29, 2019 11:13 AM
BlackMarketRacing
Dec 8, 2015 01:49 PM
gulf gt
Aug 27, 2015 10:27 AM
