Spark Plug Replacement Question
Old Feb 17, 2008 | 05:34 PM
  #31
jcb-memphis's Avatar
jcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond repute
I did mine at 25k miles using Bosch FR6LDC. No issues. I plan to just keep using these. Beru's came out (from the factory) fwiw. No issues at all, from way cold to way hot.
Best of luck to all.
I went with these because Kevin at UMW suggested they would cause the least amount of trouble. That was enough for me. He said he's seen it all in terms of things.... First cheap thing on the car car too.....
Old Feb 17, 2008 | 06:07 PM
  #32
Neil@Orton's Avatar
Neil@Orton is infamous around these parts
Originally Posted by mikerosi
Hi John, regarding the plug gap, I thought that most tuners on higher HP cars are running a gap of .025. What gap does proto suggest?
We use Bosch race plugs on our higher hp cars.
Old Feb 17, 2008 | 06:16 PM
  #33
I have the denso plugs... work fine for me....
pre gapped from the factory.
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Feb 17, 2008 | 07:32 PM
  #34
mikerosi's Avatar
mikerosi is a jewel in the roughmikerosi is a jewel in the roughmikerosi is a jewel in the rough
Originally Posted by nerdhotrod
.025-.028 for cars that are ~600 crank+.
Yes that`s what I thought, thanks nerd
Old Feb 17, 2008 | 07:42 PM
  #35
S4corrado996TT's Avatar
S4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really nice
Thanks everyone for sharing info!
Old Feb 23, 2008 | 01:54 PM
  #36
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
Well, I did the spark plug install last night and it went fine. I have a few questions about it though:
1) I did not think to put any anti-sieze on the threads - Is that ok? The IC's are still off, so I can go back and put some on fairly easily if it's necessary...
2) The coil packs went on the plugs fine, but did not click at the end. In fact when fully seated, they were about 1/4" out from the motor, as if they were spring loaded. I could push them in, but they would spring back that 1/4" every time. They all behaved the same way and I tried each one several times to get a click, but not such thing...does this sound correct? I seated them fully with the screws at 7.5 lbs. torque.
3) Does anyone know which bank is Cyl 1,2,3 - passenger or drivers side?
Old Feb 23, 2008 | 02:14 PM
  #37
Neil@Orton's Avatar
123 is the left bank if standing behind the car
Old Feb 23, 2008 | 02:42 PM
  #38
jimmer23's Avatar
jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !
Originally Posted by John D
1) I did not think to put any anti-sieze on the threads - Is that ok? The IC's are still off, so I can go back and put some on fairly easily if it's necessary...?
Aluminum heads. While you're still in there go back and do it just to be safe.
2) The coil packs went on the plugs fine, but did not click at the end. In fact when fully seated, they were about 1/4" out from the motor, as if they were spring loaded. I could push them in, but they would spring back that 1/4" every time. They all behaved the same way and I tried each one several times to get a click, but not such thing...does this sound correct? I seated them fully with the screws at 7.5 lbs. torque.?
Same thing with me John, no worries. Some click and some don't, and the coil packs on mine were "springy" also. Just torque them down and it'll be all good.
Old Feb 23, 2008 | 02:52 PM
  #39
ThePunisher's Avatar
ThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud of
Hi, on my 996 TT i'm running k24 turbos at 1,2 bar and still with Beru Spark plugs OEM.
What would you suggest, to stay with this configuration or to upgrade to another spark plug ?
And in this case, which spark plug is the best ?
Thank u guys
Bye
Old Feb 24, 2008 | 11:56 AM
  #40
John D's Avatar
Thanks Neil, Jimmer...
Old Dec 14, 2009 | 09:14 PM
  #41
adam699's Avatar
adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !
markski
Hey Mark,
Sorry to bring this one from the dead, but are you talking about IK20s? I put them on as gapped .044 with stock boost and I'm having a hell of a time with missfires.
Old Dec 14, 2009 | 09:18 PM
  #42
Part Number: PK20PR-P8
we gap them to .024 or even .028... I do not think them come at .044 from the factory...
9.66
click to view
Old Dec 14, 2009 | 09:26 PM
  #43
raineycd's Avatar
I had the IK20s and put them in gapped from the factory - tons if misfires at WOT. I put the Bosch GT2 spec copper plugs in and they are fine. I am sure if you gap the IK20's properly, they would be good as well!
Old Dec 14, 2009 | 09:35 PM
  #44
adam699's Avatar
I got Denso IK20
They did say .044" on the box.
http://www.sparkplugs.com/results_ap...1&AAIA=1388347
These guys recommend .035"
P.S. Most of my missfires were noticable at idle...go figure.
Also, after googling I see that other boosted forums recommend .67mm which should be around .025"
Old Dec 13, 2013 | 10:47 AM
  #45
randomquickness's Avatar
randomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to behold
So I think I may be due for some coil packs and plugs based on some hesitations under heavy boost.
I just wanted to verify, are the 997tt coil packs actually better than the 996tt packs and completely interchangeable?
also, what plugs do you recommend for a car with just an exhaust and tune?
Thanks guys!
