Blown Six Intercoolers
Old Feb 20, 2008 | 08:46 AM
DMaffo's Avatar
DMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud of
i did 20 passes at kayuga last year!!! twenty (20) !!!!!! in one afternoon... NO issues!!! I love them... as a matter of fact... the stock hoses did great.. i have half AP ones and the rest stockers... lol..long story on that one... markski knows...!!!
Old Feb 20, 2008 | 08:52 AM
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
The OEM hoses work fine with the B6's, however, you will have to modify the plastic IC surround, as you would with all larger aftermarket IC's. Also, I believe the hole into the engine compartment has to be enlarged a bit for good hose clearance...They can be made to fit very much like the OEM IC's, but the plastic IC surround has to be trimmed to allow proper fitment.
Old Feb 20, 2008 | 03:01 PM
WOODTSTER's Avatar
According to Todd K, if you are doing his kit you want his big *** I/C (and they are
impressive). I asked the same question. My intercoolers will support ANY amount of mods that I do in the future.
MK
Old Feb 20, 2008 | 03:04 PM
Originally Posted by S4corrado996TT
Hey Markski, Marty and John. If I am going to go for Proto PE700, what IC will best fit my need and PE700 kit? Tks!
Yes they will be just fine....
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Feb 20, 2008 | 03:12 PM
DMaffo's Avatar
the stock plastic IC brakets did need some trimming. Not rocket science... guys!!
very easy to do... everything else was pretty much a bolt on. the holes in the side of the car didnt need buyt could use a trim too... I didnt bother...,
Old Feb 20, 2008 | 06:41 PM
unvmy996's Avatar
Originally Posted by str8blst
I just had a new set installed in my car a few weeks ago and really like them. Paul from Proto commented that they looked just as good as the EVO ones. I took the money I saved and had Paul fab up some custom piping. From what I understand they redesigned the end tank connectors ( I think that's what they are called)
On a side note does anyone have information regarding some of their new products? Y-pipe and intake plenium?
i didnt see he Y pipe or the intake plenum on their site .....
Old Feb 20, 2008 | 08:32 PM
Sker66's Avatar
Sker66 is a glorious beacon of lightSker66 is a glorious beacon of lightSker66 is a glorious beacon of lightSker66 is a glorious beacon of lightSker66 is a glorious beacon of light
Tell me about Todd K's intercoolers.....
cost
fitment
hose compatability.........etc.
Old Feb 20, 2008 | 08:39 PM
John D's Avatar
I believe they are 4.5" thick vs. 3" for the B6's and they are made to mate up to the 2.5" proto piping/Y-pipe with 2.5" silicon hose...
Old Feb 20, 2008 | 08:41 PM
Sker66's Avatar
Woodster.........Is that true??
Whats the cost for the upgrade?
Old Feb 20, 2008 | 08:42 PM
silver's Avatar
silver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to all
Great IC's. I bought mine off ebay and it too did take a while to get. I was impressed with the quality. Making the shrouds fit is doable and you can leave out the rubber grommets so the clips that hold the intercooler into the metal frames will fit. Takes a little work but not hard and very nice piece for the cash.
Old Feb 20, 2008 | 08:48 PM
cost
fitment
the dimensions are : 3.5x9.5x12.4
mine are 4.5x8.8x12's.
Todd does his on the car and utilizes every available inch for the end tanks.
Its about a week of work. His run 3 times the ones of blown6. He makes the end tanks as a one off... vs someone who has the endtanks casted
markski
9.66
click to view
Old Feb 20, 2008 | 09:10 PM
vividracing's Avatar
will someone with the Blown6 or EVO intercoolers measure the inlet OD diameter so I can make a simple adapter so you can still run our boost hoses. just pm me.
Old Feb 20, 2008 | 09:21 PM
John D's Avatar
Dan, The B6's are delivered with OEM style fittings on both ends. Some of us have modified the B6's with larger piping on each end for direct hose w/hose clamp attachment to compliment larger Y-pipes, bigger turbos, etc..
Old Feb 20, 2008 | 09:50 PM
We can pull off the CNC machined fittings on our hoses so you can do a direct hose fit. Just need to know the diameter.
Old Feb 20, 2008 | 10:18 PM
John D's Avatar
Dan, I cut mine off, but I know the EVO silicon hoses fit right in because that is what I used on the B6 previously. So whatever the EVO hose fitting is...that is your answer, you probably know...
