Alarm chirp?
Old Feb 27, 2008 | 05:31 PM
ttpower's Avatar
ttpower is infamous around these parts
Alarm chirp?
Hey guys, A quick question. Is there any way at all to get the standard alarm system on the 996 Turbo to chirp while locking and unlocking the car using the standard key remote? Is not, what is the simplest way to add this feature on? Hopefully not a new aftermarket alarm system? Any help appreciated!
Old Feb 27, 2008 | 05:36 PM
leeshdw's Avatar
leeshdw is infamous around these parts
I would like to know also. I have to keep looking at the headlight/taillight for the flash to confirm locking/unlocking. Sometimes I forget to look and have no idea if it was locked.
Old Feb 27, 2008 | 06:27 PM
ttpower's Avatar
Exactly! Any help appreciated.
Old Feb 27, 2008 | 06:31 PM
TunaRollZ's Avatar
TunaRollZ is a glorious beacon of lightTunaRollZ is a glorious beacon of lightTunaRollZ is a glorious beacon of lightTunaRollZ is a glorious beacon of lightTunaRollZ is a glorious beacon of lightTunaRollZ is a glorious beacon of light
subscribing!
Old Feb 27, 2008 | 06:35 PM
atlshaver's Avatar
atlshaver has a spectacular aura aboutatlshaver has a spectacular aura about
The only "solution" I have ever heard is to unlatch the center console, causing the chirp showing a fault. Not really a solution, though...
Old Feb 27, 2008 | 07:38 PM
mtesh73's Avatar
mtesh73 is infamous around these parts
as a default, when you lock the car the horn should sound once, no sound when the car unlocks, just light indicators. when locking, press the lock button on the remote 2x rapidly, if you push just once you will be in "silent" mode.
Old Feb 27, 2008 | 08:30 PM
EMR's Avatar
EMR
EMR is infamous around these parts
I was also wondering how you know if the car is locked or not, thanks.
Old Feb 27, 2008 | 09:17 PM
Chuck Jones's Avatar
Chuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond repute
Great info...just went into the garage and tried your suggestion and the car horn gives a guick "beep"....so that technique works!! Another reason to read these forums.!! Thanx.
Old Feb 27, 2008 | 09:54 PM
mmmmm's Avatar
mmmmm is infamous around these parts
doesn't that turn off the motion detector also?
Old Feb 28, 2008 | 08:56 AM
ttpower's Avatar
Fantastic info, thanks! It works just as you say. I think there is just one disadvantage though, I believe locking it twice turns the motion sensor off.
Old Feb 28, 2008 | 10:03 AM
wross996TT's Avatar
If you leave a fault sensor in "open" position (like the center console lid) or if you hit the button twice you will disable the interior motion sensor. The beep you hear is to tell you there is a fault in the alarm system...it is not confirming the alarm is set. There is no way to set the factory alarm to give an audible alert for locking or unlocking.
Old Feb 28, 2008 | 10:32 AM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
Depending on the year model, I have a 2004 TT and can get a RemoteTop; same place that you get your SmartTop. It has all these functions +. You just missed the last group buy. Just search for SmartTop and look at their website.
Old Feb 28, 2008 | 10:36 AM
ttpower's Avatar
Thanks for the clarification. This ie very helpful to know. I guess my next question would be is that what would be the least expensive aftermarket upgrade I could get that would give the 'chirp' capability while both locking and unlocking the car without actually creating a fault situation. Any help appreciated.
Old Feb 28, 2008 | 10:47 AM
MY996TT's Avatar
RemoteTop has these functions... thanks to Matthew at GMP Performance, the last group buy was about $240 per unit.
  • 996 Cab: Operate the soft-top with your original factory-supplied remote-key(s), no reprogramming of the key(s) or the car necessary. A Selectable One-Touch operation will, once started, complete the soft-top cycle automatically by itself.
  • 996 Coupe & Boxster: Operate the windows (and sunroof on 996 Coupe) with the original factory-supplied remote-key(s), no reprogramming of the key(s) or the car necessary. A Selectable One-Touch operation will, once started, close the windows (and sunroof) or open the windows automatically by itself.
  • 996 Cab & Boxster: Selectable "Always-Arm" Mode, which will enable the passenger cabin ultra-sound motion detector alarm when the soft-top is OPEN.
  • All vehicles: Selectable Lock-In feature locks the doors once you start the vehicle or start moving. In contrast to the original Porsche Lock-In feature which can only be enabled or disabled at the dealership, our controller lets you decide if you want that feature, and even better, it also UNLOCKS the doors when you switch the engine off. A detail the Porsche engineers seemingly forgot.
  • All vehicles: Comfort window control allows you to use the electric windows for 15 more minutes after you turn the ignition off. Also enables window control after you have unlocked your car with the remote control. This allows you to sit inside and IMMEDIATELY use the power-windows, no need to put the key into ignition first.
  • Bonus Feature: Audible feedback ("chirps") using the alarm horn when locking/unlocking the car by remote. (For technical reasons this feature is not guaranteed to work on all models / model years).
Old Feb 28, 2008 | 11:27 AM
wross996TT's Avatar
There have been several problems associated with remotetop...do a search. They even say it may or may not work. I know of no easy solution.
