BMC Filter Cleaning
Old Mar 2, 2008 | 05:20 PM
r34dy2walk's Avatar
r34dy2walk is infamous around these parts
BMC Filter Cleaning
What exactly do i need to do in order to clean the filter?
About to take the BMC out of the stock airbox and clean it for the spring time thats about to come.
also, any instruction on how to get the filter out?
Old Mar 2, 2008 | 05:28 PM
DERBOOST's Avatar
DERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of light
Undo bolt on the right side, then loosen the large clamp to the engine(left side), pivot the entire filter box up and to the left and remove to bench. Remove the screws and the filter box comes apart in 2 halves, filter drops out. Clean with the k&n cleaner available anywhere, let dry, Reoil with only the most miniscule amount of oil, hardly any at all, let sit overnight, wipe off all excess oil (very bad for the MAF) and reinstall.
Old Mar 2, 2008 | 05:30 PM
r34dy2walk's Avatar
see the oil part worried me as well. i figured the oil would destroy my new MAF. what kind of oil am i using to reoil it and where exactly am i oiling? sorry for the questions, just never did this before.
Old Mar 2, 2008 | 06:11 PM
kilrgt's Avatar
kilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to behold
Its in the KN cleaner/re-oil kit. Its red and DO NOT over spray, you don't want another new MAF.You are spraying oil on the filter, I have always re oiled from the side furthest from the MAF.
Old Mar 2, 2008 | 06:19 PM
r34dy2walk's Avatar
well... im assuming you spray a very very light coat of oil over the whole filter?
Old Mar 2, 2008 | 06:27 PM
DERBOOST's Avatar
Yes just the lightest coat, better to have to little than to much. You can get the k&n kit at checker,kragen,autozone etc .... I spray only the side away from the maf, then let it sit, it will bleed through, if you have to much you can always wash again and start over. You really almost want it kind of dry.
Old Mar 2, 2008 | 06:37 PM
r34dy2walk's Avatar
how often do you do this?
HIGHcard
Sep 24, 2015 08:09 PM
sparks
Sep 8, 2015 03:03 PM
shifter_
Sep 8, 2015 12:07 PM
Weebs
Sep 7, 2015 11:42 AM
